Question about Kenmore Elite 45986 Front Load Washer
Washer Machine Kenmore model 417
I took off the inner bearing of kenmore washer tub I don't know how to put it back, it's with spring. I can't put the spring back with the inner bearing.
I need help,
Raffi
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#$
Posted on Oct 01, 2010
Kenmore washer 417
Your rear tub bearing may be bad.
Oct 21, 2013 | Washing Machines
I have a kenmore frontloading washer, during the spin cycle a noise like grinding can be heard, grinding can also be heard when turning drum by hand...help
its the drum bearings that support the inner drum,you need to replace these bearings,the problem with this is it was manufactured by frigidaire for kenmore and you cant just buy the inner bearing and lip seal as it comes with the outer rear half of the outer.tub where as with maytag neptune or whirlpool duet you can drive these bearin gs out and re-use the tub half,but you can't buy just the bearings and seal for a frigidaire front loader
Aug 31, 2012 | Kenmore Washing Machines
I have a kenmore elite washer mod.#110-27062602
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27062602&pathTaken=partSearch
Assuming that this is the Oasis type washer, see the Whirlpool Service Manual for their Cabrio washer which is basically the same as the Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
It has troubleshooting and teardown procedures.
May 08, 2010 | Kenmore 22422 Top Load Washer
Kenmore door to tub spring has come off
If you are talking about the inner spring that holds the door bellow to the tub, it's going to require two hands to get the spring to go back in the groove. You will need to carefully remove the bellow from the front opening of the door, first. On the 417 models, such as yours, the bellow is usually glued in place aorund the door frame and held in place by a spring to the tub. Use a putty knife to carefully peel the rubber form the washer facing. Once completed, you can glue it back in place with some appliance adhesive. To get the spring back in the groove on the tub facing, you will need to start at the top and have someone hold it on place as you work your way around the the tub. It's a real bear to get back in at times. Let me know if this helps you. Please post back if you have questions.
Dec 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore wasing macine tub is off track
heres how to accces the washer insides
http://www.youtube.com/watch?v=vogysB7XOc8
the washer being "off track" sounds as if perhaps a spring holding the machine centered has snapped, look toward the rear bottom unit there should be a spring going from the tub to frame holding it to the middle
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer 92573210
4 springs on bottom of washer 3 from tub to top of base hidden, 1 from rear tub to bottom of base straight down, hole in inner lip of base, to counter weight of motor.
Nov 19, 2008 | Kenmore 22642 Top Load Washer
Kenmore spin cycle thumping noises
I just went through the same issue with my Kenmore front loading washing machine. I assumed (and a Sears repairman also told me) that it is the bearings. After I took the drum assembly out, I saw the rear drum broken and the inner tub hitting the outer tub. I ordered the outer drum assembly and only when I took the inner drum assembly out I realized the the "Spider" attached to the inner drum (and spindle) was broken. Entire drum assembly cost $417 + shipping and it may be cheaper in the long run to buy a new washer. I like the front loaders because they save water and good for the environment, but the US manufacturers have not yet perfected the technology like European manufacturers (or they don't want the machines to last too long just like cars). Anyway, I am looking into welding the spider tomorrow. If not will return the outer tub assembly and buy a top loading washer for $300!
Dec 07, 2006 | Kenmore 44102 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
