Question about GE GSL25JFPBS Side by Side Refrigerator
No water i have GE GSL25JFPBS ice is working fine everything else also working fine. pls tell me how do i solve this prb thanks
Your Freezer section is set to cold. I had the same problem. Turned its adjustment so it was not so cold. About 3. A day later I was getting water again.
Posted on Aug 30, 2008
Nothing exect the ice maker works
need to know more about your problem. if ice mker is working then freezer is ok and the fresh fod area what about it l. tell me more . mm feed back pls ..
Sep 19, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Cannot get water out of front despenser but can get Ice
found that when I used the crushed ice option, the lines would freeze up. Cubes were ok. Take everything out, including the ice, and turn it off for about 12 hours. Then check to see if it works again. If not, wait a little longer to let it fully defrost. If it still does not work after 24 hours, then you might need service.
Jul 09, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Gsl25ifr no water or ice thru door but icemaker is fine. also, when in ice mode on door the led dims along with the light bulb by dispensor
board on back of unit behind panel on right side,
check for capacitors bulging on top they are supposed to be flat.
I had this problem with two capacitors replaced them and now working fine
Aug 05, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Jul 25, 2009 | GE Monogram ZDI15C Automatic Icemaker
Water dispenser wont work, the ice dispenser works fine. And the ice maker is working.
Hi, Try these out.
  1. Clean the drain tube
  2. check refrigerator and ice-maker for level
 please rate my solution..
Apr 10, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser not working, ice is working
The mother boards go all the time on these from what I read. I had the same problem. It is located under the silver plate in the back of the frigerator.
Mar 23, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE side by side refrig. quit dispensing water
take out the bottom bins in the refrigerator and remove the cover thats on the back for the light and then use a hair dier and thaw out the coil of tubing until the ice melts.
GE GSL25JFPBS Side by Side Refrigerator Logo
233 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
