While I was running the upgrade for my 60 gig Creative Zen Vision W, it indicated that the upgrade failed. After that, my Zen, which had been working previously, was no longer recognized by my PC. When I turned it on, I got an error message "Hardware Problem." I disconnected and reconnected the battery and rebooted, with no change.
  • 5 more comments
  • bigtimebob1 Aug 08, 2008
    I have to take the battery out to shut it off; it won't power down otherwise. When I turn it back on while inserting the battery, it still gives me the "Hardware Problem" message, and doesn't go to any menu.
  • bigtimebob1 Aug 09, 2008
    Windows XP home edition. The upgrade is version 1.10.01
    still not helped
    I don't understand your instruction.
    I would if it was new I contacted creative and they told me they did not have parts and do not work on these anymore
  • bigtimebob1 Aug 18, 2008
    the hardware problem will not let me proceed to attempt to try
    Genius:
  • 1,447 Answers
Hi-
Its going to cost you more if your going to have it repaired, buy a new one instead.
Posted on Aug 18, 2008
    Master:
  • 763 Answers
Try to install a new USB DRIVER or configure the add hardware tools on your control panel of your computer. if not,
format your mp3 to refresh your device. you should transfer the important files to your computer before getting formated. hope that helps!
CHARCOIS
Posted on Aug 09, 2008
    Master:
  • 623 Answers
If this mp3 is new it would be better if you take it back to the shop
  • ritchie dempacco
    ritchie dempacco Aug 09, 2008
    connect to pc
    go to my computer
    right click properties
    hardware
    click mp3
    action then scan for new hardware
    Scholar:
  • 191 Answers
  • Check that the MP3 Player Recovery Tool supports your player.
  • Ensure that you are using Windows XP®Service Pack 2 32-bit, Windows XP Professional x64 Edition or Windows Vista™ (32-bit or 64-bit version).
  • Back up the contents of your player, if possible, as recovering your player may require it to be re-formatted.
  • Make sure your player battery is at least 50% charged.
  • Moses Clive
    Moses Clive Aug 09, 2008
    MP3 Recovery Tool Requirements
    Before attempting to use the MP3 recovery Tool, please verify you have read
    the following requirements.
    • Ensure that you are using Windows XP® Service Pack 2
      or 64-bit version).
      may require it to be formatted.
    • Make sure your player's battery is at least 50% charged.
    Ensure that you are using Windows XP® Service Pack 2 32-bit,
    version).
    There are various versions of the Microsoft Windows operating system. Depending
    on the version you have, settings or applications on your computer may differ.
    To check which version is on your computer:
    1. Click Start, and Run.
    2. In the text field, type winver, and then click OK.
    The window that appears will show you which version of Windows installed on
    your PC (1). If your operating system has a service pack installed, you will
    see the service pack listed (2).
    recovering your player may require it to be formatted.
    In order to back up your player using Windows Media Player 11:
    (1.) Open Windows Media Player 11.
    (2.) Select your player on the left hand side. There will be a "*"
    icon listed next to the name of the player.
    (3.) Select one of the following categories: Artist, Album, Songs or Genre.
    (4.) Drag each of the contents under the category you have selected to the
    Sync List menu on the far right.
    (5.) Click the Start Sync tab in the bottom of the Sync List to copy the files
    to your PC's hard drive.
    Please be sure your player is charged to at least 50%.
    (1.) Connect the player to a USB port on the back of a desktop PC, to a powered
    hub, or to a power adapter (separately available).
    (2.) Check the display for the charging icon.
    • As the display times out after a few seconds, press any button on the player
      to reactivate the display.
    • If the battery is fully depleted, the charging icon may not be displayed.
      Check that the blue power LED (visible behind the Play/Pause or behind the
      Power button depending on the player) is glowing on and off repeatedly. This
      indicates that the player is successfully charging. After 1 hour of charging,
      power on the unit to activate the display. The charging icon should be displayed.
    (3.) Allow the player to charge for at least 6 hours. During this time, if
    charging from a USB port, please ensure your PC does not enter a power conservation
    mode (Standby, Sleep, or Hibernate) as this will interrupt charging
  • Moses Clive
    DOWNLOAD THE PLAYER RECOVERY TOOL AND THAT SHOULD TAKE CARE OF THE ISSUE
    http://www.creative.com/products/mp3/MP3...
  • 13,433 Answers
The internal software is possibly corrupt now, try another computer. if the problem persists you need to send it to creative to be fixed. the firmware can only be reloaded back into the machine at home if it is detected, if its not detected the firmware tools available at creative can't fix it.
  • 6,487 Answers
Try first resetting the unit because this really happen if a software update failef that the program of it will be damage so resetting it will be able top bring the unit bck to its defaul settings and that may help you to continue the update..
Hope that helps...........
Posted on Aug 08, 2008
  • Mark Gil
    Mark Gil Aug 09, 2008
    Try first resetting the unit, buit after that still have the same problem you may need to replace it from creative already...
    Master:
  • 521 Answers
Remove the connections and join them again properly in proper position ,replace the battery and check.
  • tech expert12 Aug 09, 2008
    try with another battery
  • tech expert12 Aug 14, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
    Brigadier General:
  • 3,614 Answers
May i know the OS you use, and the current update you try to upgrade the player
    Genius:
  • 3,422 Answers
1.Disconnect the ZVW from the computer.
2. Turn off the ZVW.
3. Remove the battery.
4. Move and hold the power button to the power on position while re-inserting the battery.
5. Hold the Power button until the Recovery Mode menu appears.
6. Select the Format option from the menu.
7. When the format is completed, select Cleanup from the menu of options.
8. Then Restart the ZVW and see if it boots up normally."
Can't put music on my zen vision m 30 gig
it might be the files ur using maybe there not compatable or maybe corupt
Jun 23, 2009 | Creative Labs ZEN Vision:M Digital Media...
Upgrading Creative Zen?
Go to the Creative support site and upgrade the old MP3 player. The new Player will sync with mediaplayer and you can install music.
Feb 01, 2009 | Creative Labs Zen Touch MP3 Player
Problem transferring MP3s to Zen Vision 30GB
I have a Zen Vision M 30G, and this is what worked for me.(Widows XP home Edition. First you're going to want to transfer all your files back to your PC to back them up. I've found that even though you can't transfer from your PC to Zen, you can transfer from Zen to PC. Connect your player, and after your Pc recognizes it go to My Computer>click on your player, it should show up as "storage media.">then you right click on it, then select "reformat." A warning should pop notifing that you will lose all you data. Click yes, It should take less than a minute to complete. So essentially you have just wiped your Mp3 player's hard drive clean. Now transfer all your backed up files back to your player.
Aug 16, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen problems
You can try a firmware upgrade, but weird sounds are not good - indicate that a circuit diode has gone bad. Find out if you are still in-warranty, and replace the player.
Jun 18, 2008 | Creative Labs ZEN Vision:M Digital Media...
Can't move new files to Zen Vision M
Download recovery tool off creative's website.
Oct 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen vision m 60 Gb dont want to be charging
Upgrade the firmware to version 1.62.02. That should solve all your problems. Go to www.creative.com to download the firmware.
Sep 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
Menu, Play/Pause, Quicklink, Back Buttons not working
This happened to me. The problem was the case was cracked and was permanently resting on the buttons inside the zen. I ended up buying a new one. Upgraded to the 60 gig model at that time.
Jul 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
56 people viewed this question
 Grubhead
Grubhead
