Question about Dishwashers
Dishwasher kenmore 665.
I checked the capacitor wiring - OK.
I pulled the motor to see if anything was obstructing it. Problem is I don't know what it should look like. pulling the motor was easy. one screw and it twisted right out. the shaft on the motor may have disintegrated. not sure. the tip of it looks like a sharpened pencil.
There is a round plastic cover that covered the entrance to the inside of the housing. I pried it out, it has a heavy O ring around it. the pieces on the inside fellout, to not sure of the order. but there is what appears to be an impeller which also has a shaft just like the one coming out of the motor, that looks like a sharpened pencil. the other end of this impeller has a little white ratchet that looks like a large version of the ratchet you find inside a ball point pen. It appears that the end opposite the ratchet is broken.
  • jshelhamer Aug 08, 2008
    there is a pn on what is probably the impeller, but it's worn too much to make out. there's also a pn on the round cover that housed the impeller. don't know if that helps any: 8531019
    Brigadier General:
  • Dishwashers Master
  • 3,614 Answers
I will look into it.. may i know if u can find the part #.
Posted on Aug 08, 2008
SOURCE:
665.13049k110 kenmore dishwasher won't drain.
Check that the drain pipe exit point is higher than the water inlet and drain connection on the machine, thats a comin problem, also check and clean the drain pump situated at the front of the machine at the botom underneath the cover
Oct 03, 2017 | Kenmore Dishwashers
Kenmore dishwasher model 665-16629000 is leaking out the front. Checked the gasket, ok. Checked the door screws, took the door off, no cracks.
Before I took the machine out from under the cabinet, I would take a really strong light and some hand mirrors and try to see it leaking with the front cover off.
There is not a good chance this can be done.
Other than that, I would pull the machine out from the hole and test it where I could look underneath.
Should be either a drain hose of an inlet hose giving you trouble.
God bless your efforts.
Apr 15, 2016 | Kenmore Dishwashers
Breaker at dishwasher trips right after water has filled.Spray arm has not turned.
There is an electrical short circuit, check/reverse the leads going to the pump or heater.. Sounds like controls and water valve are fine. If wires are not connected to the correct locations you need a new motor because it is internal.
Aug 26, 2012 | Kenmore 665
My kenmore dishwasher model 587.1414 does not
Check spray arm for obstructions and if it is clear the motor impeller could be slipping or water system may need a good cleaning with CLR.
Eric
Jan 14, 2010 | Kenmore Dishwashers
Kenmore Dishwasher won't drain
If you opened and closed the door and it started, that sounds like a bad, door switch in the console.
But you did hear a hum sound when it tryed to drain, it could be the drain solenoid, or the motor/pump assembly.
Take off the bottom access and look at the solenoid when it starts to drain, the piston in the solenoid should move freely, up and down with the white drain flapper that it connects to.
Also check for bad wiring connections at the power junction box where the power hooks up to it under the dishwasher, i have seen the wire nuts either come loose or burn off due to loose connections.
Jul 02, 2009 | Kenmore Dishwashers
Kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Jun 02, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher limited edition model 665
Anyone know anything about heating elements, mine won't dry the dishes, thanks
Mar 30, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Kenmore Dishwasher does not wash
Stew, Im not really sure what model you have 665, 587, 363 or what. If it's a 665, it sounds like the wash motor is not getting power. Remove the toe panel and look at the start capacitor. See if one of the wires came off during the reinstallation. Should be on the left side of the wash motor. If one of the wires is off, wash motor won't run. If that's ok, check the main harness to the motor. Catriver
Sep 17, 2007 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
