I have a COMPAQ DCHS09U Fast Wide SCSI Had Disk connected to a QLogic C21 32-bit PCI Fast and Wide SCSI Host Adapter Card with four other Fast and Wide SCSI Hard Disks and other SCSI Devices. The QLogic C21 Host Adapter is Installed in an AOpen AX45B Pentium 3 Motherboard. The Problem that I'm having is the COMPAQ DCHS09U Hard Disk isn't Spinning Up on Power-Up but instead is Spinning Up during SCSI Device Scan Process, which delays this process by a long time. So I need information on How to set the Jumpers on the COMPAQ DCHS09U Fast and Wide SCSI Hard Disk. Could you please provide me with this information? Thank you, David A. Smith
  • 689 Answers
You can change the configuration accordingly, as indicated below
Posted on Aug 09, 2008
  • 84 Answers
When combining internal and external devices, only one of the internal connectors can be used.
http://stason.org/TULARC/pc/hard-disk-floppy-controllers/P-R/PROMISE-TECHNOLOGY-INC-Up-to-15-Fast-Wide-SCSI-2-d.html
Posted on Aug 08, 2008
  • 13,433 Answers
Try disableing the Start/Stop Unit command with the jumper
http://webserver-1.wescorp.com/wescorp-library/pdf-library/DEC-CPQ-HP/IPB-&-QR-1/app_b_scsi_hard_drive_config_charts.pdf
I suppose when this is enabled it waits for the command before starting the motor. see if this solves the issue.
  • Ekse Aug 08, 2008
    I was looking at the wrong harddrive
    On yours you need to add a jumper to autostart enable
    see page 16
  • Ekse Aug 09, 2008
    There you go.
I have a MSI-7309 motherboard and I was wondering if there was a pci card that I could get to give me more sata connections then just the 2 that I have filled up.
Hello there,
Yes there is it should look like the image below. They call this raid card or simply PCI SATA card it sells for $15 -20++.
There are a lot to choose from, consider your requirements some cards do have e-sata or IDE. it also comes with one 18 inch sata cable. Use up to 4 SATA I or SATA II Devices using this SATA I Speed Host Adapter, since PCI Bus is not Fast Enough for SATA II Speed if you wish to save money this card will provide you with access to all four SATA Ports at 1.5GB/s per port. Use New 1TB Western Digital Seagate or Hitachi Drives with your older PCI Based computer. supports up to 2TB of Hard Drives.
Hopefully this information helps.
Thank you for using FIxYa.
Aug 14, 2011 | Intel Motherboard
I can install this device on windows server 2008 64 bits, LSI Logic Symbios Host Adapter Storage (8751d) SCSI Controller
go to computer go system propertys go device manager you will adapter in this with yellow mark on it right click the trouble shoot it.
Feb 14, 2011 | LSI Logic Symbios Host Adapter Storage...
Hi.. please help... After installing scsci card im getting message as bios not installed. It says that scsi bios not installed and that in device manager both scsci card and tape drive are installed...
Hi when you start the pc and goes to the scsi utilities and scans for device its not finding the device attached to it sioit gives you this message you can see if the terminator connect to the device is properly connected and its in its place ,also press CTRL+A to get into the adapter setting and in the scsi utilities section scan the devices if it finds it then check the id of the device how much its set to it should not be the same of the scsi card id .by default scsi card id is 7 but be sure.
Dec 10, 2010 | Adaptec APD-29160 MAC 64 BIT PCI SCSI...
Not getting a drive letter from Compaq SCSI RAID setup
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
Good luck.
Jul 04, 2009 | Compaq (128293B21) (128293-b21) SCSI...
My Computer did not access Western Digital Hard Disk, Model No. WD 1600 AABB Caviar SATA.
Good morning! Please make sure that the drive’s power and SATA cables are properly connected. If the Serial ATA host adapter card is installed in a 64-bit PCI slot on the system motherboard, move the card to a 32-bit slot.
Verify that only one power cable (either SATA or legacy) is connected to the drive. Check to see that the power connector and SATA interface cable are securely attached and that the
SATA host adapter card is properly seated in the PCI slot.
The Serial ATA interface connects each drive in a point-to-point configuration with the built-in SATA port on the motherboard or with the SATA host adapter card; therefore eliminating the master/slave relationship as required with EIDE. Each drive utilizes its own
cable for data transfer rates. Jumper settings for Western Digital Serial ATA hard drives are mainly used for enterprise storage environments.
Most third party controller cards and RAID adapters are recognized as a SCSI device under Device Manager. This is normal and will not affect your drive or system performance.
To verify if the Serial ATA drive is recognized by the system, Right-click on the My Computer icon, select Properties, left-click on the Hardware tab, and click on Device Manager in the window. Double-click on Disk Drives. Your new Western Digital Serial ATA drive should be listed as a "SCSI Disk Device" or "Serial ATA Disk Device." If not, make sure that all cables are securely attached and that your system BIOS has been properly configured. regards
May 12, 2009 | Computers & Internet
Need to find out to what Qlogic model is this SUN OEM HBA =2
I don't know what kind of OS you used
but you can find the driver from here
http://driverdownloads.qlogic.com/QLogicDriverDownloads_UI/SunOEM.aspx?oemid=124
just download what you need
search "x6767a"
Jan 28, 2009 | Sun 2GB PCI Single FC-AL Host Adapter (p/n...
I need info on the make of scsi card that is bundled with scanner
It may be an old Adaptec SLIM-SCSI series. Very popular on Late 90s
1. Adaptec PCMCIA Fast SCSI Controller ( 1807600 ) - SCSI Controller ...
    "Adaptec Storage SCSI Controller Card, Storage 1807600, Adaptec PCMCIA Fast SCSI Controller."
    www.superwarehouse.com/Adaptec_PCMCIA_Fast_SCSI_Controller/1807600/p/88814
2. Adaptec SlimSCSI 1460 review - IT Reviews
    "Adaptec is the king of SCSI connectivity devices and currently offers two PC Card (PCMCIA) SCSI cards. The 1460 is the jack-of-all-trades model, ..."
    www.itreviews.co.uk/hardware/h82.htm
3. Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0 ...
    "Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0.2183.1 - Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter."
    www.soft32.com/download_171850.html
Jan 18, 2009 | Umax PowerLook 2100XL Flatbed Scanner
SCSI Inquiry Command Failure w/Tandberg TDC 4120 tape drive
Try putting the tape drive on the last scsi termination point.
Jan 01, 2009 | Adaptec Cables & Converters...
I can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
