Dell 926 photo printer paper feed
The paper refuses to feed. it leans to the left and the mechanism makes 'jerky', trying to feed sounds
  • Anonymous Oct 01, 2008
    i have the same problem - there is nothing jammed in the printer roller
  • CarlG-Hill Jan 25, 2009
    Exact same problem. Purchased the photo 926 printer from Dell outlet as a refurbished item and it has never worked properly. I think I may just give up soon and buy a new printer of a different brand altogether! Any help would be appreciated . . . .
    Problem Solver:
  • 5 Answers
There is something jammed in the pick up roller area.
Posted on Aug 09, 2008
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Jul 25, 2009 | Office Equipment & Supplies
I have a dell photo printer 926 that will not let the paper feed. no amount of pushing or trying the rollers will not take the paper.
plz check the printer paper roller if it is ok or not , if it is ok then after that uninstall the printer driver and then reinstall the printer driver again
May 27, 2009 | Dell 924 All-in-One InkJet Printer
Dell Photo 926 printer no longer feeds paper correctly
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Dell 926 All-In-One InkJet Printer
Dell 926 all-one inkjet printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Oct 24, 2008 | Dell 926 All-In-One InkJet Printer
Dell 926 printer
Go to Dell Journal ID: 08086MJJNF
Article ID: 316455
Date Published 1/4/2008
Last Revised: 3/25/2008
Go to and top right type in 926 printer; it will bring you to the next page, click on the first result: Install Dell 926 All-In-One Priter Drivers. This should help you. Follow all the directions exactly!
***Did you uninstall the first 926 driver before you did anything else. You must uninstall the first driver and install the driver for the second 926 printer.******
Mar 26, 2008 | Dell 962 Photo All-In-One InkJet Printer
200 people viewed this question
