Seagate 320GB HD I copied an image file to it using Acronis software, and after a week or so when I rebooted I got a "Disk Read Error" an dpress Ctrl Alt Del" to restart computer.... all it does is loop itself with same message. I have reformatted and tried to install a fresh copy of WinXP Pro but it crashes without doing the installation. Now it says it is 305.25 GB instead of 320 GB... anyone HELP Please... Thanks Ray
  • sweep002 Aug 10, 2008
    Hi Steve,
    Thanks for trying, but I gave up in frustration as it would not even
    reformat again.... took it back to the store where I bought it and
    exchanged it for a SATA HD (I'm going to buy a new computer shortly and
    I will install this other hard drive in it.
    This is the second large hard drive I have put in this one since March
    and I feel that there may be something about this computer and large
    hard drives....
    Thank you very much for trying to help me, I really do appreciate your time and effort.
    Regards,
    Ray
    Sergeant:
  • 395 Answers
Don't worry about the size reported, 305GB is same as 320GB because 305GB = 305*1024*1024*1024 = 327491MB
Try deleting all partitions and reformatting (but do NOT choose Quick Format). Also try chkdisk /R C: to check for errors.
Posted on Aug 09, 2008
Error
If you have an external hard drive, you can use software such as Acronis, to make a copy of that drive to save everything in an image. Get a new drive to install in place of the old one. Next you can use Acronis to copy the image on the external hard drive, back to the computer, onto the new hard disk in your computer.
Jul 19, 2013 | Microsoft Windows Vista Ultimate Edition
Tip
How to copy program using True Image
<p>Acronis True Image allows the computer to back up the data. The programs can periodically back up the entire hard disk, either online or in another physical disk. It can also backup individual items, such as files, folders or programs. <br /> <p><br /> <p>1. In a clear picture, click "File backup" from the main window. "The backup file is opened. <br /> <p><br /> <p>2. Navigate to the folder in the program with the left panel. For example, if you want the program to copy folder with the software Menezes "in" Program Files "directory, navigate to" Program Files ". <br /> <p><br /> <p>3. Folder from the right window. <br /> <p><br /> <p>4. Select the destination of the "target" drop-down box. For example, if you program to a "D" of the secondary unit. <br /> <p><br /> <p>5. "Backup Now" button. <br />
on Jun 22, 2011 | Computers & Internet
Having trouble booting two Raid-0 discs on Asrock Z77 Ex4 UEFI
RAID implementations will vary from controller to controller, and even from bios to bios revision or version for the same controllers.
You should "image" the raid on the old board, then delete the raid on the old system.
In the new system, you need to treat these drives like they are new, blank hard disks. Any partitions will need to be removed, and the RAID created on the new board. Once this is done, you can use your partition imaging software to drop the data back onto the new RAID partition. Seagate I believe has imaging software available in Seatools, or you can use something like Acronis True Image or GHOST.
May 16, 2012 | Computers & Internet
Ihave a sagate 320 inturnal HD that was installed on my desktop Comp. 1.5 years ago I am getting window massage to download all my data due to the HD failing. I am looking at the date code and it appears...
It sounds as if the SMART measurements on your Seagate 320GB hard drive are triggering the Windows message advising that the drive is failing.
You would be best advised to backup your data from this drive to a different drive or on to DVD media (depending on how much data is involved).
To test the failing Seagate disk, download a copy of Hiren's Boot CD which is a CD image file (.ISO) and must be burnt to a blank CD disc - then boot the computer with the failing disk from this CD - then select DOS Programs on the initial menu, then choose Hard Disk Tools and then HDAT2 - this is a tool which will let you try to recover any bad sectors on your boot disk.
On the Hard Disk Tools menu there is also a SMARTUDM - HDD S.M.A.R.T. viewer which will let you examine exactly which areas of the Seagate disk are giving the problem leading to the failure message.
Jan 08, 2012 | Seagate Barracuda 7200.10 ST3160815A -...
I have been using HTS545032B9A300 320GB drive in my Samsung R428 laptop. One day, suddenly, its shuts down and never boots up. It never gets beyond setup. It hangs and showing "Entering into...
When start your laptop,is their any spinning sound in your hard disk(Hitachi)?
If so, try to go setup the bios ,just watch the laptop either detect or not,
If your laptop detect the hard disk ,again install to the laptop, and remove the new seagate just for recover the data through following step.
Please download hiren boot bootable ISO file ,
Download the iso file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Mazor problem is most of the user, burn ISO file in data mode and the result, it could not run in boot time.
Burn the iso file, under image burning option from any nero .
Boot from cd, no need to setup bios.
DONT PANIC follow all the steep It is very simple. (Use the down arrow key.)
1.INSERT CD TO CD TRAY
2.Boot from cd
3.Select start boot cd
FOR REPAIR THE HDD DONT PANICI
Choice hard disk tools
1.select HDD regenerator>enter
wait create it auto mode
2.Enter(If you have one HDD)
3.Press "1"ENTER for scan and repair (With out lose any data)
4. press 3 for REGENERATE ALL SECTORS
I will sugest press for "1" and enter
press( 1-9 )any one number and type mb and ENTER
Repair will Start soon.
Insert a pen drive
Restart your laptop and boot from cd
1.Boot from cd
2.Select mini windows
3.you can explore every drive (hitachi) and can copy paste to pen drive.
ALL IT WILL BE POSSIBLE IF YOUR HDD CAN SPIN AND AND READ .
Hope this helps.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 18, 2011 | Hitachi Travelstar 5K500.B...
Scansnap Scanner stops suddenly when scanning multiple pages and "hangs" for a little while, stating that it's scanning the same page, before giving an error message saying that it is offline. ...
I had this problem happen also and found that it was related to Acronis True Image Home 2011. When this program was uninstalled, the problem went away. I had even rebuilt the Windows 7-64 bit OS and the problem existed until Acronis was again removed.
Nov 11, 2010 | Fujitsu ScanSnap Manager
320GB seagate freeagent, cant open some of the files.
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
Sep 17, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How do I transfer data from my hard drive to added external drive
you can this many different ways. The most straightforward is to go to the drive and select "folder and file options" in the view menu and selct "show hidden files", that way when you copy and paste you will get every single file. The other way is to use a program such as Acronis Tru Image and use the clone option. I am assuming that you want an image of your C:\ drive.
Sep 14, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
MIGRATE EASY SOFTWARE-PARTION SIZE DID NOT INCREASE
when u clone a drive it copies the same size to if you are using vista it is easy to expand go into admin tools then computer management then click on your drive and expand it
Dec 03, 2008 | Acronis Migrate Easy 7.0 (AME7)
I have Dell Dimesion 4300S with Win2k pro as OS. I had 130GB IDE and now got a 320gb HD. Using Migrate Easy trial software, I migrated to the new HD, for partiotion, I used "proportionate" so that new HD's...
Did you enable Copy NT Signature? If so, you need to unplug the old drive after cloning and BEFORE the first startup with the new drive. Two drives cannot use the same NT Signature on the same machine.
Dec 01, 2017 | Acronis Migrate Easy 7.0 (AME7)
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
