Question about Panasonic AG-HVX200 Mini DV Digital Camcorder
Headphone jack port broken
The jack port for the headphone on our HVX-200 is broken and needs to be repaired, some where in Bay Area, CA. Any suggestions for who could help us with this?
This is a known problem with this model of camera. We have two and have the same problem with both. Call up Panasonic and they will give you info on sending it in.
Posted on Aug 25, 2008
Broken headphone jack, no sound threw laptop speakers
change the entire jack you will get it for 200 bucks by breaking the jack you shorted out the speakers
Apr 05, 2014 | Toshiba Satellite A105-S4074 Notebook
My ipod classic is only playing out of 1 headphone, it is the same with all headphones
Step 1:
Your trusty iPod has been a close and reliable friend for a long time but one morning only the sound of air comes through the headphones. The likely culprit is a loose or broken headphone jack that is in need of repair. Rather than spend an exorbitant amount of money to have someone fix it you can easily make the repair on your own and have your iPod friend back. Read on to learn how to fix a broken headphone jack for a fifth generation 30GB or 60GB iPod video.
Open the iPod case with a small flathead screwdriver by slipping it under the centerline of the case. You will find a series of clips you have to release in order for the case to open up about an inch. Locate the headphone jack connection and verify that there are no broken wires. Fix broken wires quickly by twisting the wires back together and wrapping with electrical tape. Test the iPod for sound by connecting your headphones to the jack. Replace the wires completely if you find static coming from the iPod jack. Fold a business card twice so that it wants to unfold and slip it into the case over the blue sponge. This creates the pressure needed to hold the jack in place and allow a solid connection. Push the case together without engaging the clips on the side and test to make sure the jack is now working. Try a thicker business card or fold the first one again to get enough pressure onto the jack connection if the first card didn't fix the problem. Press the case fully together until the clips click into place. Use extra care when inserting your headset to ensure the jack remains in place.
DigiExpress - iPod Video / iPod Classic Headphone Jack installation
http://www.youtube.com/watch?v=MXXgV6YNGkQ
Feb 22, 2013 | Apple iPod classic MP3 Player
Headphone jack socket In Sony Vaio laptop has broken
1) The easiest method is to get a USB headphone and it shall solve your problem. You can easily insert the headphones in USB port and can enjoy the music of any sort you like.
Now, obviously as you must already possess a great headphone so my optimum solution to you for time being is to get a USB Stereo Audio Adapter. You shall only have to spend 7$ max and shall be able to get a decent adapter. I am also posting in a link for you if you want to buy it.
http://www.amazon.com/Syba-SD-CM-UAUD-Adapter-C-Media-Chipset/dp/B001MSS6CS/ref=sr_1_1?ie=UTF8&qid=1351072087&sr=8-1&keywords=headphones%20usb&tag=vglnk-c679-20
Lastly, any sort of repairs can also be done to your laptop. If you can post picture of the damage area and the current status, I would be able to give you a way to mend your laptop as well. But that is for later :-). Enjoy.
Oct 24, 2012 | Sony Vaio White Pcg-71913l 15" Intel Core...
Broken headphone jack on dell d630
Yes! if the plugin is not secure the connection will be poor causing unstable reception in the audio department.
May 10, 2012 | Dell Latitude D630 Laptop Computer PC...
Headphone port broke
Each service shop has their own rates, the laptop will need to be dismantled down to the motherboard level to repair the damage. I suggest you get a rough estimate before you authorize the job.
Apr 04, 2012 | HEWLETT-PACKARD G56-127nr Notebook
I have an Acer Aspire Notebook. When I plug headphones into the audio jack there is no sound, however, the sound works fine from the notebook speakers. Can anyone help me?
Hi, May I know if have tried alternate headphones and if they are the same?Does the headphone work when wiggled within the port if yes then the issue is with the headphone jack being loose and you would need to send the computer for a repair if covered by the manufacturers warranty as the headphone jack needs to be replaced. Thank you for your time.
Nov 23, 2010 | Acer Aspire One A150-1006 Notebook
Headphone Jack issue Sansa View 32GB
Buy a broken one with the headphone jack intact off Ebay and switch the jacks.
Sep 08, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Headphone Jack is NOT working properly
Check your sound device levels. you may need to enable that headphone port before it is usable. you can do this in the control panel tab. reinstalling your sound drivers wouldn't hurt also.
Jan 28, 2009 | Toshiba Satellite A105 Notebook
Headphone jack broken speakers wont work
Yes, since the Headphone pin is stuck in the Jack, you are not getting audio from Speakers.
You should have noticed that connecting the headphones to the Jack will block the audio coming from the Speakers and the same is the current situation.
You can either try removing the blocked part using a Tweaser or get it repaired.
Jul 31, 2008 | HP Pavilion dv9000z Notebook
Ipod Nano 1st gen 4gb. Headphone jack signal in mono, not stereo.
most likely headphone jack is broken. option one is to take it to the apple store and have them repair it. option 2 is to go on e-bay and buy a replacement jack and try to do it yourself. best option is to sell it on ebay as broken/needs repair. Someone who knows how to fix them will buy it from you and you can use the money you get to buy a good used working iPod. There are always tons of nanos for sale on ebay.
Jul 27, 2007 | Apple iPod nano
Panasonic AG-HVX200 Mini DV Digital Camcorder Logo
373 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
