Question about Dell 3000cn Laser Printer
Replaced Toner- It Still Won't Work
I replaced the magenta toner on my Dell 3000cn. The error message still says "Replace Magenta Toner". I took it out and put it back in, turned the Dell off and on. Same message. Won't print.
  • itswendy Aug 08, 2008
    I will try it. Thank you.
  • brian695 Nov 17, 2008
    I have the same problem with the yellow toner. I've taken it out, reseated it, turned the printer off/on... all a number of times. Nothing is working. Is there a possibility of overriding the error/toner?
  • 446 Answers
It is possible that it is not installed correctly, ensure that it fits rightly on its place, oterhwise there is no way it would resume printing, reset the unit once again open and close the covers and turn the switch on and off to reset
Posted on Aug 08, 2008
Our printer has just had a new cartridge put in, a reconditioned one and it is just saying processing and not doing anything when it prints
I replaced the magenta toner with a Dell magenta toner and after about 50 copies the machine is displaying "004-321 Restart Printer". I've done this numerous times and the message won't go away nor can I print.
Feb 24, 2011 | Dell 3000cn Laser Printer
Ricoh CL4000DN. I recharged the magenta toner using the OEM cartridge. I replaced the chip as instructed and all elements snapped together without difficulty. However, now there is a "check toner...
Hi, the chip on those toner bottles stores information about how much toner is left, so once that chip registers an empty toner bottle, it won't work even if you attach it to a new toner bottle. You'll need the chip from a new toner bottle, or one that hasn't registered no toner.
Jan 22, 2011 | Ricoh CL4000DN Laser Printer
Error 9-355 on dc12 xerox
That is a magenta toner empty message, either the magenta cartridge is empty or there is an issue with the magenta toner dispensing.
Nov 14, 2009 | Xerox DocuColor 12 Printer
WHAT DOES THE ERROR MESSAGE 377 MEAN?
It means that there is Magenta toner density sensor error.Try to reset or replace Magenta development unit and then turn the printer off and back on.It should fix the problem,providing that the Magenta toner supply channel is not clogged up and functioning properly.
Oct 08, 2009 | Ricoh Aficio AP3800C Laser Printer
Error message OKIC3200n printer
I called the OKI help number, in the manual, and they told me that the second line of the error message, was just an additional reminder, to replace the magenta toner.
Sep 29, 2009 | OKI C3200n Led Printer
Wrong cartridge 093-982 cyan toner unsupported
are you using a dell-branded toner cartridge? if yes, then you should replace the toner cartridge sensor and machine control unit (MCU). if no, you can enable the non-dell toner mode on your printer's operator panel. how? press menu, down until "configure" & press select; down until "maintenance" & press select; down until "non-dell toner" & press select; down until "on" & press select.
Aug 12, 2009 | Dell 3000cn Laser Printer
Hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
51.22 is a Magenta laser scanner error.
Try removing the magenta restarting the printer and reinstalling.
If that does not work you likely need a laser assm.
You might want to call a tech. to replace.
Apr 01, 2009 | HP Color LaserJet 2600n Printer
Replace toner message still displaying
Have you already tried powering the printer off/on to see if this would clear the error? If so, are you using a Dell branded toner? If not, this could be why the printer has not recognized the replacement. It could be you recieved a bum toner cartidge, although this does not happen often, it can still happen. If you take your old toner cartridge and put it back in the printer, does it recognize it? If so, perhaps it is the toner cartridge.
If it is a bum Dell toner cartridge, Dell carries a seperate warranty on toner, apart from the warranty on the printer. Call Dell laser printer tech support. They will need your order number for the toner and have the cartridge handy as they will need an identification number off of the cartridge.
Mar 28, 2009 | Dell 3000cn Laser Printer
I have replaced the toner but am still getting the replace toner message.
My message error was sepcific for magenta after I removed it to refill it. After refilling, cleaning metal contact points, resetting the metal tab which prevents message of "low toner", I put the cartridge back in and received the "magenta toner not installed" message. I turned off the printer (safety first!) , I then pushed the button left of the hole where you slide the cartridge in, There is a squarish hole with a circular or cynlinder shaped button in that squarish hole. Use a small screw driver to push and hold it in. While the button is held in I gently rotated the cartridges so that my magenta cartridge was no longer in view, (rotate them counter clockwise). I released the button, shut the door, then turned on the printer.
Sep 09, 2008 | Konica Minolta magicolor 2300DL Laser...
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
Dell 3000cn Laser Printer Logo
376 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
