Hi there, i have a maxtor 3200 500gb external hard drive to which i inadvertently plugged my lap top power supply into. This is 19v dc as opposed to the 12v dc it should be. I have obviously blown the pcb which unplugs from the hard drive. Where can i source a replacement please?
    Sergeant:
  • 395 Answers
It would be cheaper to buy a new chassis. You can buy these without a hard drive in and then put your hard drive inside.
http://www.maplin.co.uk/searchtemplate.asp?criteria=USB%20HARD%20DISK%20CRADLE
Posted on Aug 09, 2008
I have a Maxtor external driver and the AC adapter is not working. I need a new AC adapter and local stores do not have it. How can you help?
There are "generic" power supplies that might meet your needs.
This is a response I gave to another user who had a different external HDD and needed a power supply.
The hard drive unit itself should be able to supply you with the required DC input voltage (hopefully there is some kind of label on the enclosure).
You could try one of these or something similar. It comes with 6 interchangeable heads and has adjustable DC voltage. This is just one of many available.
http://www.amazon.com/Hosa-ACD477-100-240V-Voltage-Adaptor/dp/B000Z31G3M
I cannot guarantee any of these supplied heads will fit your particular drive (same with the dc voltage). Some local retailers
often have these types of adapters and you might be able to determine what size you need by looking at one. Most of the
Externall HDD need 12VDC and 18+ watts of power.
Here is an online site also.
www.12Vadapters.com
I have used DC units similar to these in the past when I have lost a power supply.
Hopefully with a minimum of effort you can get a working solution.
Feb 24, 2011 | Maxtor Computers & Internet
Do I need a seperate dc supply for my Ultra traveldrive usb 2 Why won't it install on my lap top.
> do I need a separate power-supply?
It depends. If the disk-drive inside the enclosure is a 2.5-inch "laptop" disk-drive, then it will draw the necessary electrical power through the USB cable. However, if the disk-drive is a 3.5-inch "desktop" disk-drive, it does require an external power supply.
Will it install on some other computer?
Dec 18, 2010 | Memorex Ultra Traveldrive - 160GB USB Hard...
Do I need only one cord (usb) to connect to my laptop?
The "physically-smaller" external hard-drives draw power through the USB cable.
The "physically-larger" external hard-drives require an external power-supply (just like a laptop requires an external power-supply).
Check the casing for a plug where the electrical power would come in; if none, then the unit will draw electrical power through the USB cable.
May 31, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
AHrd drive Beebing and not reconized by my lap top
try using another usb cable and another usb slot on your computer. the drive is not recieving enough power from ther computer.
Jul 14, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Mistakenly plugged maxtor one touch 2 into wrong power adapter
Well Most Likely The Circuit Board Burnet Out Since Its 12V And When Plugged Into A 19V Supply It Will Burn Out Instantly Because It Over Charges The Circuits. So Its Not Possible To Repair Such Damage But You Can Take Out The Hard Drive And Plug IT Into A Desktop Computer And Use It At Home Or As An Online Hard Drive To Store Files
Jun 18, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
Lost power supply
I think you might find this link most useful, from the Seagate Community Forums.
http://forums.seagate.com/stx/board/message?board.id=onetouch&message.id=1973
In short, others have had great difficulty buying Maxtor replacement power adapters, however you can buy a generic 12V, 3A DC power supply for $15-20 from a number of sources. Confirm your actual power requirements by referring to the product label on the drive itself.
Hope it helps,
Mike
Dec 02, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Power supply details for Maxtor 500 gb, external hard drive and ? manual
The PSU for my Maxtor 500Gb 9NZ2A4-500 drive is 12V DC, 2A rating, 2.1mm "plug" with centre "hole" as positive.
Regards, kbsguru
Nov 06, 2008 | Maxtor Hard Drive
Maxtor OneTouch III 500gb
One hard drive failure mode is a power circuit short. Contact MAXTOR support on their web site for a possible warranty replacement. BTW, SEAGATE owns MAXTOR now.
Feb 24, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor personal Storage 3200 Power Supply [K01PWR3200]
i own the exact same drive. i'm looking for a spare power supply, came across this website, and saw your problem. the power supply is 12 volts dc at 2 amps. the connector that gets plugged into the hard drive: center pin is power (positive) and outer "shield" is ground (negative). hope this helps.
Dec 29, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
