Question about LG LSC26905TT Side by Side Refrigerator
Ice maker not making ice
Water is flowing but ice is not being made
  • 639 Answers
Dear FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
UNDER THESE CIRCUMSTANCES YOU WILL NEED TO CALL SERVICE . SORRY!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS.PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OUT!
Posted on Aug 26, 2008
Ice machine won't make ice! kenmore 363.9537883 bought whirlpool filter 4378411RB water comes out of door but pressure isnt good. Told me i needed a new filter. Is this the problem or something else?
The filter is for water AND the ice maker. The ice maker expects a certain amount of water to flow into it during the fill time. If no water flows at all into the ice maker, then suspect the clock mechanism of the ice maker.
Aug 14, 2016 | Kenmore Refrigerators
Ice maker stopped making ice
hi,
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Oct 03, 2008 | Whirlpool GS6NBEXR Side by Side...
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Icemaker clogs with ice. Water flows with icemaker unplugged.
ur solenoid could be allowing water to flow freely its in the back its blue try replacing this solenoid and see if this fixes the problem they r cheap and easy to change
Feb 27, 2010 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Model # trt18GREW5 ice maker will not make ice, and no water flowing thru valve w/ water supply on and water tube to ice maker disconnected
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Water doesn't flow unless the ice maker calls for water which it does immediately after dumping the previous load of ice.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 18, 2009 | Microwave Ovens
Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
Aug 29, 2009 | Kenmore Refrigerators
Water is not flowing to ice maker but flowes thru door. the ice maker is cycling as it should but with no water
I turned off the freezer for a little while, then used my hair dryer to blow hot air where the water flows in to the ice maker. In a few hours it was making ice again.
Aug 24, 2009 | Kenmore Refrigerators
Stopped making ice
First of all is the water flowing into the ice-maker? Check the solenoid valve which regulates this water flow to the dispenser & ice maker. If water is flowing in, the ice-maker's thermostat may have malfunctioned, since this thermostat is separate from that inside the fridge...........sodeep
Aug 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi
If the ice maker has completely stopped producing ice then check to see whether the ice maker has been turned off. For this you need to look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary. If the ice maker is producing ice poorly i.e. if it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
LG LSC26905TT Side by Side Refrigerator Logo
79 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
