Question about Canon PowerShot A60 Digital Camera
Shutter won't close all the way
When I turn the camera off the shutter gets stuck and will not fully "collaspe" back in to the camera- any ideas to fix this?
Thanks
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Posted on Aug 11, 2009
My canon powershot SD 1000 will take outdoor pictures but wont take any with low light and the flash won't work. I see that someone else asked the same question but I can see what advice was offered
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Recommend trying the pencil tapping fix listed in the link. It worked on my SD1000 with the same problem.
Jun 04, 2011 | Canon PowerShot SD1000 Digital Camera
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
The screen on My Canon Power Shot SX 120 IS camera will not show any images when I turn it on. It simply shows black, if I take a picture, the picture will record on the memory card but it is also just a...
Nov 18, 2010 | Canon PowerShot SX100 IS Digital Camera
My Canon S2 IS Powershot camera LCD screen turned black
A stuck shutter is another common failure mode for digital cameras, ESPECIALLY for the S2 IS (you should actually complain to Canon at 1-800-OK-CANON. If it is indeed a sticky shutter, they have been fixing this for free). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Hope this saved you $99.
Apr 29, 2010 | Canon PowerShot S2 IS Digital Camera
New pictures I am taking with my camera are showing up completely black. I can view previously saved pics on the SD card on the screen, but any new pics only come up black. Any ideas what this could be?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Feb 21, 2010 | Canon PowerShot S2 IS Digital Camera
I have a powershot s3 is and when I turn it on I have no pic. It just started doing this and last time I hit the display button and the pic came up. It will show images of pics that I have already taken....
Nov 08, 2009 | Canon Cameras
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
My cannon powershot s3 IS is taking pictures that are black. what can i do to get it back to normal
Oct 24, 2009 | Cameras
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Canon PowerShot A60 Digital Camera Logo
553 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
