Question about LG LSC26905TT Side by Side Refrigerator
LG LSC26905TT How do you get the handles off or the doors.??? It won't fit through the doorway....yuck thanks
You must remove the doors.. There are instructions in the manual on how to do it.
Posted on Aug 22, 2008
  • dcb328 Aug 22, 2008
    After I sent this response I read the owners manual. On page 7 it tells you to simply grasp the handle with both hands and lift up.
    They come off easily.
How do I move my Proform Treadmill to another room without taking it apart completely. It will not fit thru the doorway and too heavy to lift alone.
I have moved this treadmill several times since we bough it. Up and down stairs and from one room to another. I also used to be a mover so I hope this helps. I am not sure what model you have but i have the 525x. To move it I make sure the incline is set to zero, list the track/running section and lock it into place with the locking pin located on one of the handles. The Proform i have has attached wheels so i lean it back and get it close to the door standing straight up. Once there I turn the treadmill slightly and get one side through the doorway then I pull it halfway through the doorway. If its a tile, wood or linoleum floor make sure to put a rug under the treadmill to protect the floor. It will also helo it slide through the doorway easier. Then tuun the treadmill slightly the other way and get the other half through the door. Once there i tilt it back on its wheels and move it where i want it.
Jun 18, 2010 | Proform Crosswalk 500 Treadmill
I need a replacement water line for my LG LSC26905TT. The line is cracked and when I try to dispense water the line leaks.Where can I look for this product? Thanks for any info. Alan
If the water is leaking from the freezer door hinge the door would have to be replaced as the waterline in the door is foamed in place.
If the leak is from the back where the plastic lines are they are replaceable.
Contact LG @ 1 800 243-0000 and give the exact location of the bad waterline since there a couple on the unit.
Jan 19, 2010 | LG LSC26905TT Side by Side Refrigerator
Door removal Need to remove doors to clear handles too wide to fit thur our doorway into house
THE HANDELS LIFT UP AND RELEASE THEY ARE STUBORN PUT A LAYOR OF DUCT TAPE ABOVE HANDLE TO PROTECT THE PAINT OF THE DOOR THEN **** UPWARD
Jan 12, 2010 | LG Refrigerators
Lg lsc26905tt ice maker makes ice, but wont turn dispenser
you can look to see if something from the freezer dropped into the chute? it may have blocked the exit. Is this all new ice or has it been a while since you used it? Maybe the auger in the bin is stuck?
Aug 26, 2009 | LG LSC26905TT Side by Side Refrigerator
Refrigerator won't fit thru door.
I ran into the same problem when I moved into my old house. the door way was to small, so I had to take both doors off the refrigerator to get it through the doorway. But I found out when I moved out of the house, that I was able to open both doors and wiggle it through the doorway. It was a hassle but it was alot easier that removing the doors. Good luck.
Apr 04, 2009 | Whirlpool ED2FHGX Side by Side...
Rangemaster toledo DF 90 what is the minimum door width through which these cookers can be fitted?
Yes, the handle, doors and knobs can all be removed, in fact (If I remember correctly) the unit is delivered with at least the handle/rail at the top not fitted. I would still suggest that you visit the supplier with a tape measure and suggest that if they want sell you a unit, they reassure you by showing you a packaged unit, or demonstrate the removal of the handle.
Sep 24, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Ice Flap on my LG LSC26905TT will not close after ice dispences
ran into an LG tech today with identical problem and was told to replace a solenoid that closes the door flap.
Mar 04, 2008 | LG LSC26905TT Side by Side Refrigerator
Door Handles Loose
Pry off the covers carefully and tighten the screws. The covers will come off. You can even place a thin piece of cardboard between the screw drive and the refrigerators surface so you wont scratch it. Hope this helps
Aug 09, 2007 | LG LSC26905TT Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
210 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
