Question about Microsoft Computers & Internet
About formula i have large number of entires in one column in different rows, if a enrty repeat in any row how i guess that the entry is repeated
    Problem Solver:
  • 10 Answers
One way of finding (and removing) duplicate entries is to sort the column and put a simple formulate in a temporary column next to that column; for example - if column A has duplicates, insert a column (B) and starting in B2 put if(A2=A1,"DUP",""). Select B2 and scroll down to the bottom of your spreadsheet. Press <ctrl>-D to extend the formula in B2. Wherever there is a duplicate you'll see "DUP" in column B. If you want to remove the duplicates copy column B and Edit / Paste Special... with "values" selected (to wipe out the formula). You can then sort the spreadsheet on column B and remove rows with DUP in column B.
If you can't delete the duplicate rows and the order is important first include a column that captures the order - same trick except put row() in that column, copy / paste special the values and then you can re-sort after doing the above to have both the DUPs marked and the original order.
Hope that helps.
Posted on Aug 11, 2008
How to get all balance sheet entries tally to excel
This is a very handy process when you're totaling or subtotaling columns. On the cell that you want the 'total' in type '=sum(column letter row number),(column letter row number). The first 'column letter row number' is where you want the first cell to be started in the total factor and the second 'column letter row number) is the last cell you want added in the total factor. The help (?) section is good at explaining formulas. Hope this helps, keep this process handy if you use Excel much because it'll be helpfull each time you subtotal or total columns.
Bob
Sep 23, 2009 | Computers & Internet
How to number a column. I can't remember the short formula, something like a1+1= which would make the number two pop up in the cell underneath.
You can number rows in a column by entering a number in cell A1 (usually the number 1 but youcan start with any number) and the formula (=A1+1) in the next row. The result there will be 2. Copy that formula down the rows you want to number and they will be numbered 3, 4, 5, etc. Each row adds 1 to the previous row so if you do anything that disrupts the sequence (like inserting a row between two others) you will have to copy the formulas down again to restore the sequence. You can also use the Edit-Fill-... menu command to put a series of numbers into rows. Put the starting number in th efirst row. Highlight it and the rows that you want to number and select Edit-Fill-Series... Those numbers will not change if you insert columns or move the formulas.
Or you can use the formula =ROW(A1) in any cell to return the number of that row. (The result of =ROW(A1) is the number 1 in cell A1, the result of =ROW(A2) is the number 2 in cell B2, etc. In this case inserting rows will not affect the numbering (i.e. row A5 will always be numbered 5 even if the data in it is moved down.)
Sep 18, 2009 | Microsoft Excel for PC
I need a running balance in a column for a petty cash spreadsheet
In the first row of numbers, assume row 3 for example (leaving 2 rows for titles, put in cell E3: =C3+D3. In the next row (assuming row 4, put in cell E4: =C4+D4+E3. Use fill down to populate this formula all the way down.
Jun 18, 2009 | Microsoft Excel for PC
Need to know the formula for increasing a $3500 revenue by 0.005% per month for 24 consequtive months. how do i preform this with one formula to avoid entering it 24 different times. i know that the answer...
If the column is absolute, then use the $ before the first character and if the row is absolute use the $ before the second character in your cell designation. If BOTH column and row are absolute, use the $ before both the column and row character.
Examples: $A1, A$1, $A$1
Mar 30, 2009 | Microsoft Excel for PC
Works 8 Word Process set Repeating Page Column Headers
Choosing the single cell below rows you want to repeat on each page and to the right of the column you want to repeat and then freezing that cell will cause those rows and that column to repeat on each page as you print. works fine on preview. However I still can't get the machine to print.
Ralph R. McKibben.
Mar 21, 2009 | Microsoft Works 8.0 for PC
Finding the correct row num
You would have to combine the use of 2 functions. The Address and Match funbctions.
Lets say the number you want the address of is located in cell F1 and you have 2 columns of numbers. One colum in Column A and the other in column B. I will give you 2 formulas. The 1st one will return just the row number. The 2nd one will return the cell address.
Option 1: Lets say you just want to know the row reference of the number in cell F1. Place this formula in cell D1. =MATCH(F1,A1:A20)
If you have another column ytou want the row number of, place the formula in lets say cell D2 and change the column references from 'A' to 'B'.
Option 2: If you want the cell reference, place this formula in cell D1 and D2 instead of the firt formula.
=ADDRESS(MATCH(F1,A1:A20,0),1,1,TRUE)
And just like the first option, for the 2nd column, put the formula in D2 and change the column reference 'A' to 'B'.
Feb 17, 2009 | Microsoft Excel for PC
BASIC EXCEL FORMULA
Are you looking to solve any particular problem?--- because there are a huge number of possible formulas in Excel.
However, in my opinion, the most commonly needed ones are addition, subtraction, division, multiplication, and summing.
Suppose you have the following numbers typed into your Excel spreadsheet:
columns: A B C D
rows
1 20 3
2 10 4
3 15 2
4 1 2 3
Then suppose you type in the following formulas (in the D column):
columns: A B C D
rows
1 20 3 =A1+B1
2 10 4 =A2-B2
3 15 2 =A3*B2
4 1 2 3 =sum(A4:C4)
Then the following answers will appear in the D column:
columns: A B C D
rows
1 20 3 23
2 10 4 6
3 15 2 30
4 1 2 3 6
Sep 29, 2008 | Microsoft Computers & Internet
Display calculation result in a previous cell
Look into the =SUMIF function, it sounds like this may be what you are looking for.
Hope this helps!
Apr 09, 2008 | Microsoft Excel for PC
Excel formula
Assuming that all of your data is in a single row number 4 and between columns N and PF
Try:
{=OFFSET(N4,0,MATCH(TODAY(),N4:PF4,0)+1,1,1)}
The MATCH function looks up the value of today() in the range N4 to PF4 and returns the number of columns offset from the beginning of the range. (The 0 here does an exact match)
The OFFSET function returns a value from a cell a specified number of columns from a reference cell, in this case N4, which is the first column that contains the search data. We need to add on to this value to skip the Interest column.
Regards,
Daryl
Jan 25, 2008 | Computers & Internet
Duplicacy in excel sheet
Since you are searching the data by the phone number , first select all the data in the spreadsheet and sort it in ascending order by the phone number.
Then, assuming you have 5 columns of data A through E, and the phone numbers are in column E, with row 1 occupied by column headings, use the following formula in cell F2=IF(E2=E1,"Duplicate",1)
Drag this formula down column F till the end of your data
Select the entire data and do an auto filter
In column F filter the data by Duplicate and delete all these rows
What remains should be unique data
Dec 19, 2007 | Computers & Internet
Open Questions:
What is Microsoft office applications? Microsoft office is a set of interrelated desktop applications, servers, and services, collectively referred to as an office suite, for Microsoft Word: a word processor included in Microsoft Office and some editions of the now-discontinued Microsoft Works Microsoft Windows and macOS operating systems. Microsoft Excel: a spreadsheet. Microsoft released the first version of Excel for the Mac OS in 1985, and the first Windows version (numbered 2.05 to line up with the Mac) in November 1987. Microsoft PowerPoint: a presentation program used to create slideshows composed of text, graphics, and other objects, which can be displayed on-screen and shown by the presenter or printed out on slides. Microsoft Access: a database management system for Windows that combines the relational Microsoft Jet Database Engine with a graphical user interface and software development tools. Microsoft Access stores data in its own format based on the Access Jet Database Engine. Microsoft Outlook: a personal information manager that replaces Windows starting in Office 97, it includes an e-mail client, calendar, task manager and address book. Microsoft OneNote: a notetaking program that gathers handwritten or typed notes, drawings, and audio commentaries. Notes can be shared with other OneNote users over the Internet or a network. Microsoft Publisher: a desktop publishing app for Windows mostly used for designing brochures, labels, calendars, greeting cards, business cards, newsletters, website, and postcards. Microsoft Project: a project management app for Windows to keep track of events and to create network charts and Gantt charts, not bundled in any Office suite. Microsoft Visio: a diagram and flowcharting app for Windows not bundled in any Office suite
Dec 28, 2017 | Microsoft Computers & Internet
Computers & Internet Logo
151 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
