Question about Dell Latitude D600 Notebook
Overheating? I am running Window XP Professional. While using my laptop this morning, everything just froze and I had to manually turn it off. Since then, booting up seems to be a problem. It will either boot up part way and freeze, or it will not start to boot up at all (the Caps On light blinks)
    Genius:
  • 2,028 Answers
This generally caused by a bad battery or memory chip. Start by removing the battery and starting on AC only. Then remove the memory and try one chip at a time in each slot. This can also be caused by a hard drive failure, but most often it's the other two. The blinking light will most likely blink a certain number of times, indicating an error code. Go to Dell's support site, and find the diagnostic codes list for your machine, there is a list for each of Dell's machines, and the list has both light an sound (beep) error codes. This could tell you exactly what the problem is, however,some are vague, but will point you in the right/general direction.
Posted on Aug 08, 2008
    Sergeant:
  • 395 Answers
This is usually CPU overheating (loose heatsink?).
To be sure it is not your XP, boot from the recovery CD and see if it will stay running for a while.
Check memory modules are in OK and not loose in sockets.
Otherwise, you will need to check the CPU+Heatsink and CPU fan.
If you put it in a cold place overnight and when you switch it on next morning it gets much further, then it sounds like overheating problem due to heatsink or fan.
I have a ffus2613lp. Yesterday the alarm started going off with the doors closed. The inside temperature raised to room temperature. I pulled it out, cleaned everything, including compressor/coils. ...
Good Afternoon Friend,
I understand the Hi Temperature alarm was going off on your Frigidaire refrigerator, model# FFUS2613LP, and the temperature was room temperature. I also see that you pulled out your appliance and cleaned everything, including the compressor and coils. You turned your refrigerator back on and it froze a cup of water before you went to bed. However, when you woke this morning, your refrigerator was back at room temperature. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it keeps warming to room temperature. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Refrigerators
I HAVE A ZING WINDOW CE LAPTOP .AND I HAVE A NOKIA N73 AND ITS PC SUITE CD .I COPY CD INTO PENDRIVE .WHEN I INSTALL PC SUIT IN MY WINDOW CE THERE IS CAME THIS MASSAGE -SOFTWARE NOT VALID FOR WINDOW CE. HOW...
You may not be able to. Windows CE is a very small Windows operating system. That is, there are just basic components used to run your laptop.
From the website PDF manual:
To install and run Nokia PC Suite:
At least 300 MB of free disk space
- One of the following operating systems:
- Windows 7 32-bit and 64-bit editions
- Windows Vista 32-bit and 64-bit editions (Service Pack 1)
- Windows XP Professional x64 edition (Service Pack 2)
- Windows XP (Professional or Home Edition) (Service Pack 2 or later)
- Administrator rights to the PC to install software on it
Note: To transfer music between your phone and a PC using USB cable connection in the Media Transfer mode, you need to have Windows Media Player 10 (or newer) installed on your PC. Windows Media Player includes an MTP driver, which is required for transferring music in the Media Transfer mode.
Feb 25, 2011 | Computers & Internet
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using it...
holding the fn key on boot will start the pre boot diagnostics if theyre clean then the heatsink and fan need cleaned out as they get blocked with dust, there should be a panel that you can remove on the back
Feb 24, 2011 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using...
Make sure the cooling fan for the laptop is not obstructed in any way or is not dirty. It's pretty common for a laptop to get plugged with dirt from normal use. Get a can of air and blow the machine out to remove dirt, lint or debris.
You could also have a defective battery, but try cleaning the machine first.
Feb 24, 2011 | Computers & Internet
I was running my Toshiba Satellite A135-S2376 when the screen completely froze. The cursor wouldn't move, and I could not restart the computer with control-alt-delete. I held the power button until it...
I've heard a lot about freezing problems on toshiba as well as others like this. Most common issues are one of two things. One is a damaged RAM module. The second is one of the video card chip sets have fried or are slightly overheating causing the laptop to shut down. Most common with Nvidea and ATI Radeon series graphics cards.
Jan 05, 2011 | Compaq Presario Notebook
Hi, I am planning to buy lenovo think pad laptop having core i3 processor, loaded with DOS. I got some market feedback that intel core i3 does not support window xp professional. Why i am so much...
Hi Sanjeev,
Just about a month back I purchased a Lenovo laptop having Intel Core i3 processor loaded with DOS.
I then installed Windows XP SP3 32-bit and there is absolutely no problem whatsoever with the compatibilty. Also, all the device drivers for Windows XP are available on Lenovo support website.
So, there should be no problem to install and run Windows XP on this laptop.
Wish you all the best. Thanks for using FixYa.
Oct 17, 2010 | Microsoft Windows XP Professional
Windows xp
it may have been a faulty driver as mircosoft has been having problems, but if you reinstalled windows then it could be a disk fault, make sure you are using a valid key. try repairing windows,
Dec 10, 2009 | Dell Inspiron 1525 Notebook
Sony viao notebook will not turn off, will not open programs either
Your laptop may be frozen. If you have it plugged up in the wall, unplug it from the wall and the back of the laptop. Let the battery run out and the computer will go off. Then try turning it back on, do the same thing you did the morning it froze, then try turning it off. If that doesn't work, then you might need to get it check at a repair shop.
Oct 21, 2008 | Sony Notebook Computer Cooling Pad Laptop...
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
Overheating problem, with fan stopping randomly
If it's overheating it's possible that either there's a problem with the fan, or the fan/heatsink is clogged with dust. If you know how to open up the laptop you can do that and use a can of compressed air to clean it out which may solve the problem. If not you'll have to replace the fan.
Feb 19, 2008 | Acer Aspire 3000 Notebook
Dell Latitude D600 Notebook Logo
150 people viewed this question
Alun Cox
