Ok, Have JVC big screen 52". Digital works, Analog doesn't, No sound. Son plugged in 360, something snapped, burn smell. Sears came out - said input tunner is fried. Where do I buy the parts? Can I fix this myself? And do you think this is really the problem?
  • 8,617 Answers
Whats the model number of your JVC ? please reply to this same post when replying
Posted on Aug 08, 2008
SOURCE:
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
Jan 10, 2016 | JVC Televison & Video
When plugged in i smell something burning and no picture or sound
Don,t keep on trying it, It could start on fire.It was (Damaged) Buy what is called a (Power) Surge,It can not be (Repaired) in that (Circumstance) they are ususally beyond (Repair)
Oct 24, 2012 | JVC 47" 1080p LCD HDTV - BlackCrystal 4...
Metal snapping noise, like a broken spring, now burning smell. clutch?
Sounds like the throw-out bearing or the pressure plate has gone out..
Jun 24, 2017 | Cars & Trucks
Trying to get sound from a coaxial cable plugging into a LG flat screen. The Tv has no Audio out puts... Only has a optical digital cable out in the back, but my stereo is older and is a JVC RX-400.. Is...
No.
Where does the TV sound REALLY originate? If it's a cable box, THAT is the same as a real audio device and it will have analog audio outputs at the very least.
Nothing is ever gained by routing audio or video through a device that doesn't use or improve it.
May 28, 2011 | Technics SC-DV290 System
I am using a JVC RX6000 video audio receiver, and i hooked 5.1 BMB brand home surround speakers to it, and connected my ASUS media player that has optical output and used optical cable to connect to the...
This is a common problem. Each input will default to analog. Even though you have plugged an optical cable into the inputs of the Receiver, you have to change that input to digital.
For example, if you connect a CD player RCA cables to the Receiver. The receiver will recognize the Analog signal at the CD input. If you unplug the Analog RCA Cables and plug in the Digital optical, the receiver will still be at it's normal default input for the CD player which is Analog. You then have to switch the input, using either the remote or it may be able to be done with the buttons on the front.
As soon as it is changed to Digital, you will get nice sound.
Hope this helps,
Happy New Year,
Mark
Dec 31, 2010 | JVC RX-7000V Receiver
When listening to playback just on camcorder i can get sound but when i plug into computer or tv there is no sound. How do i get the sound to play?
Aw, this is very rare. Both digital and analog connection no sound? First, make sure with analog connecting cable working, must be the original JVC A/V cable and 2nd, when connecting to PC, use the software provided (CyberLink) for playing and editing videos. Good Luck
Mar 14, 2010 | JVC Everio GZ-MG335 HDD Camcorder
JVC Television 56" in Digital Mode
somewhere in the tv's menu there will be something called autotune or channel settings. while in that part of the menu you should find something to change settings. also there are many inputs on the back of big screen tv's, you might try a different input like cable/antenna for instance. it may take a two way splitter to split the signal for both digital cable and analog cable. by next february the analog part of the cable may not work anyway.
May 02, 2008 | JVC AV-56P575 56" Rear Projection...
Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Mar 21, 2008 | Pioneer VSX-D411 Receiver
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Ekse
