Hi, I'm trying to create a wireless network. I went through the wireless network setup wizard, got an network name (SSID) and key (WEP). But this network is not recognized by my wireless printer. The printer wireless configuration wizard told me to look on my speedtouch website thingie (which i access by typing my IP in my web browser address bar) for a working SSID, but I couldn't find any... Please help! Thanks!
  • 320 Answers
You need check what mode is operating your printer 802.11g or 802.11b and enable this on your router
Posted on Aug 08, 2008
I don't know how to find my network key (wep/wpa key)
When you installed the router, you should have followed the instructions on how to "login" to the router, and run the "Wireless Networking Setup Wizard", to set:
* an SSID ("network-name")
* an encryption-level (use: WPA)
* a network-password
It's those values that you need to use to connect to your wireless network.
Dec 26, 2010 | D-Link DIR-615 Wireless Router
I need help getting our network key for our wireless router...
What is the model number of your dlink router?
anyway, just go to your hardwired computer:
Hardwired computer:
1. open web browser
2.in the address bar typein 192.168.0.1
3. the username:admin password:(None, just leave it blank)
4. Click "SETUP"
5.Click "WIRELESS SETTING"
6.Click "MANUAL WIRELESS NETWORK SETUP"
7.change now the SSID or NETWORK NAME (create a new name to avoid conflicts with your ol network name that was saved into your computer
8.Look for security mode, Select WEP or WPA-Personnal
if WEP select 10 number as a password
if WPA-Personnal, minimum of 8 Characters
9. type in the network key
for WEP type it in WEP KEY 1 (PLEASE DONNT CHANGE key 2,3,4)
for WPA-PERSONAL type it in PRESHARED KEY at the buttom.
10. then click on save settings on the top
Thats it.....
hope this will help you
Aug 13, 2010 | D-Link Computers & Internet
It wont print wireless
We have to connect the printer to the network first, If it is not connected, please follow the below steps.
  1. Touch Setup (c01629002.gif ) on the touch screen.
  2. Scroll down in the Setup menu, and then touch Network .
  3. Scroll down in the Network menu, and then touch Wireless Setup Wizard . The Wireless Setup Wizard searches for networks, and then displays them in a list.
  4. Touch the name of your network.
  5. If the list does not contain your network name, follow these steps to enter it manually:
  6. Touch Enter New Network Name (SSID) .
  7. On the on-screen keyboard, touch the appropriate letters and numbers to enter the network name (SSID). NOTE: Make sure that you enter the uppercase (capital) and lowercase (small) letters exactly. Otherwise, the wireless connection fails.
  8. When you finish entering the new network name, touch Done , and then touch OK .
  9. Touch Infrastructure , and then touch WEP encryption or WPA encryption. If you do not want to use encryption (a security password), touch No, my network does not use encryption , and then go to step 6.
  10. If prompted, enter the WEP or WPA key:
    1. Touch the appropriate letters or numbers on the on-screen keyboard.
    NOTE: You must enter the exact uppercase and lowercase letters. Otherwise, the wireless connection fails.
  11. When you are finished entering the WEP key or WPA key, touch Done and then touch OK to confirm. The product attempts to connect to the network.
Once it is connected to the network or if it is alreday connected, please follow the below steps on the printer.
  2. Touch Network , touch View Network Settings , and then touch Print Network Configuration Page .
After that, please note the ip address of the printer from this printed page and follow the below steps.
Please click on Start------Control Panel---Printers Folder.
Right-click on the printer icon 8500 series---- click " Properties" , and then click the Ports tab
Click Add Port .
Click TCP/IP port and put (ip address of the printer)
, and then click New Port . The Add Port wizard starts.
Click Next ,
Follow the on-screen instructions to finish adding the port.
The issue will be fixed.
Apr 19, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Now we have gone wireless how do I set up my printer as wireless.? I have a photosmart C7280 all in one
a) Locate and write down your wireless router settings:
Network Name (also called SSID) :_________________________________________
WEP key/WPA Passphrase (if needed) :_____________________________________
IMPORTANT :You must have this information available to continue with your wireless setup. HP provides
a web-based tool called the Wireless Network Assistant [URL: www.hp.com/go/networksetup (English
only)] that can help retrieve this information for some systems. If the Wireless Network Assistant is unable
to retrieve your network information, you must consult the documentation for your wireless router, the router
manufacturer, or the person who originally setup your wireless network.
b) Press the Setup button on the HP All-in-One. (wrench/spanner symbol)
c) Press down arrow button until Network is highlighted, and then press OK . The Network Menu appears.
d) Press down arrow button until Wireless Setup Wizard is highlighted, and then press OK . In a few moments, a list of detected
networks appears on the display. The network with the strongest signal appears first.
e) Do one of the following:
- Press down arrow button to highlight the name of the network that you wrote down earlier.
- If the network name that you wrote down does not appear in the list, you can enter it manually. Press down arrow button until Enter New Network Name (SSID) is highlighted, and then press OK . Then use the visual keyboard to enter the network name.
f) If your network uses security, a prompt appears for the WEP key or WPA passphrase. Both are case sensitive. Use the visual keyboard to enter the WEP key or WPA passphrase, as requested.
Note : If your router provides 4 WEP keys, make sure you use the fi rst one.
g) Follow the prompts on the display to complete the network setup.
Visual keyboard tips:
To Select: use Arrow keys to highlight, and then press OK .
For mistakes: Select Clear .
For lowercase: Select abc
For numbers: Select 123
For symbols: Select .@!
When you are finished: Highlight Done , and then press OK .
Mar 31, 2010 | HP Office Equipment & Supplies
Need my wireless SSID Name & Network key
The SSID is simply the name of the WiFi Network, the Network Key or WEP/WAP Key, is generated when you first setup a WiFi point, For the first time you must copy this key to a document & use it when you try to first login, to the WiFi network. So the only place that information can be found is in the WiFi's setup.
Feb 16, 2010 | Computers & Internet
Hi I have a MSI RG54G3 ROUTER could someone tel me where the WEP number is or where can i obtain one Please can you help
Take an Ethernet cable, and connect one computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
Look for a line of output like:
Default Gateway . . . . . . . . . : 264.468.326.124
Start Internet Explorer
Type http://264.468.326.124 and press ENTER
Login to the Router (ID/password required)
Run the Wireless Networking Setup Wizard,
and create an SSID and create a WEP-key.
Jan 25, 2010 | MSI Wireless-G RG54G3 Router
Need my WEP Key and can't find it
Hi! To find the WEP key on your DLink DIR-655 wireless router, you need to access the setup page of the router by typing at the url: 192.168.0.1, then it will show the setup page of the router. on the left side, you will see Internet, Wireless settings, Network Setting, USB Settings, Select on Wireless Setting, then it will go to Wireless Network Settings, Under that you will see, Enable Wireless, Wireless Network Name, 802.11 Mode , Enable Auto Channel Scan , Wireless Channel , Transmission Rate , Channel Width , Visibility Status and under that you will see Wireless security mode and click the pull down arrow, and you will see, wep, wpa, wpa2, once you select one of the security mode, it will show on the buttom the option to setup the wireless security. If you have any question pls feel free to get in touch..
Sep 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
What is a ssid and a wep key. I am dumb.
SSID is the wireless networks name you want to access.
WEP is a special hexadecimal key to secure your network means if you want to connect a wireless network you will have to put this key.
It will be provided by the admin
Aug 12, 2009 | Office Equipment & Supplies
Wireless doesn't work
Hi Friend,
Kindly check the below given instructions,
To access the WIRELESS (WLAN) settings window, click on the Wireless Setup button in the SETUP directory.
WIRELESS NETWORK SETTINGS
1.Click on the Enable Wireless box to allow the router to operate in the
wireless environment.
2.The SSID identifies members of the Service Set. Accept the default
name or change it to something else. If the default SSID is changed, all
other devices on the wireless network must also use the same SSID.
3.Enable Auto Channel Scan so that the router can select the best
possible channel for your wireless network to operate on.
4.The Wireless Channel can let you select the channel of your access
point. Channel availability is different for different countries due to their
regulation.
5.Select 802.11 Mode to operate in b/g/n mode. Or select specified mode
to use.
6.Channel Width, Maximum rate for 20 MHz is 130 Mbps. Maximum rate
for 40 MHz is 270 Mbps.
7.Transmission Rate, suggest keeping the Best (automatic) selection.
8.Click on the Hide Wireless Network box to allow the router to stop broadcasting its SSID.
WIRELESS SECURITY WIZARD
1.Click on the Security My Wireless Network button to enter the
2.SECURE MY WIRELESS NETWORK window.
1.Input the SSID.
2.Select the Wireless Channel.
3.Select the Encryption type. WPA-PSK is more secure than WEP 64 bit.
4.Click on the Apply Settings button to apply the settings
WIRELESS SECURITY MODE - WEP
1.WEP (Wireless Encryption Protocol) encryption can be enabled for
security and privacy. WEP encrypts the data portion of each frame
transmitted from the wireless adapter using one of the predefined keys.
2.The router offers 64 or 128 bit encryption with four keys available.
Select WEP Key Length from the drop-down menu. (128 bit is stronger
than 64 bit)
3.Specify the encryption key from the Current Network Key drop-down
menu.
4.Enter the key into the WEP Key field 1~4. (Key length is outlined at the
bottom of the window.)
5.Select Authentication type from the drop-down menu. (Shared is
better than Open)
6.Click on the Apply Settings button to apply settings.
Check and revert back
Regards,
Ayyasam
May 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless problem setup/ What is WEP?
It is the security key used for your wireless router.
When you set up any device to connect to the wireless router you will need it.You should be able to go on you computer,open internet explorer,and type 192.168.1.1 to get to your router page to see all the info needed.
Jan 09, 2009 | HP Photosmart C7280 Printer
Computers & Internet Logo
David Payne
David Payne
