Question about Sony Playstation 3 (PS3) Console
Av output cord does not work Ive tried two different cables, neither work. Initailly the picture was off so I wiggled and or tightened cable to console and that worked. At last attempt the picture was scrambled and would not fix. PS3 support is a joke and hasnt helped at all.
    Scholar:
  • 106 Answers
Your video card probably overheated and blew up. (not that uncommon, even in computers) you will need a new ps3 because the video card is part of the ps3 board.
Posted on Aug 09, 2008
I am trying to playback videos on my JVC Everio Camcorder using the colored AV cords. I hear the audio coming through my TV but there is no video/picture. I have tried adjusting the settings and tried...
First, set [SWITCH TO ANALOG I/O] to [OUTPUT]
then turn off the (camcorder) unit.
After you connect the cable (from AV connector to the TV's AV Input Connector (accepting the 3 color cables), set the TV to VIDEO mode, selecting the AV input (from your Camcorder).
Then start your playback on the camcorder ...
slide the mode switch to select the (video) mode (instead of the picture/photo mode)... press the PLAY/REC to select the playback mode, and select the desired files/frames to play.
Hope this works for you. Have you tried using the HDMI mini connector instead ? (same process, just set your TV to accept input from the HDMI input)
Jun 03, 2014 | Video Cameras
Hi our PS3 has no sound or picture. It does have the green power light on.
What is probably happening, is your PS3 is set for the wrong type of output. If you are using an HDMI cord, try switching to the AV cables that came with your PS3, and set your TV at the appropriate input to correspond with the AV hookups, and see if the picture works then.
If you are using the AV cables, it may have been set to HDMI accidentally. You need to use an HDMI cord, and hook the PS3 up to an HDMI compatible TV or monitor, and select the HDMI input. Once you get the picture working, go to Settings>Display Settings and set the display you wish to use.
May 16, 2011 | Sony Playstation 3 (PS3) Console
My xbox's video is not working, the sound works, ive tried diffent TVs but still does NOT WORK!!!!
Have you tried different cables? If you're using AV Cables (the red, yellow, and white cables) then there might be something wrong with the yellow cable (the video cable). The best thing that you could probably do is simply just buy another one. Or you can try an HDMI cable for better quality sound and picture. But the HDMI cable is only compatible with TVs that support HDMI. You can find cheap HDMI cables online, I just bought a 6 ft. cable for only $4.
Feb 03, 2011 | Microsoft Xbox 360 Console
Emerson CR202EM9. The video on video 1 and 2 are not working. I am trying to connect my xbox, and the sound works on both video channels but the screen is black. whats wrong? the yellow video cable is...
Try wiggling it the video cable. I have a TV with a messed up video plug-in from pulling cords off it, and when we wiggle it then the screen will flicker the image and we keep wiggling it till the picture stays on the TV screen.
Nov 02, 2010 | Emerson CR202EM9 TV
Every time i connect my av. chord it gives me the e74 but when its just the pwer chord it works ive bought a new av chord it has the same thing showing up
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Feb 18, 2010 | Microsoft Xbox 360 Console
Nintendo Wii AV Cables not work
It could be a problem inside the Wii where it only outputs a signal through HD. Have you tried a different TV using the original cables? If the problem persists I would recommend calling Nintendo.
Jul 27, 2009 | Nintendo Wii Console
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
My Sega turns on but it wont show a picture
Well it depends on the type of cable you got... if you got those red, white, yellow cables :) and it doesn't work try wiggling the cable in back of your genesis (common problem among most MAJORLY with the old style adapter) or chances are your cables broken or you have a shot av output
Apr 30, 2009 | Sega Genesis Console
My ps3 has no picture or sound...
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
Jan 22, 2009 | Sony Playstation 3 (PS3) Console
Philips 26
There is an input imbalance. Either try connecting your cables to different inputs on your TV, or try connecting to different outputs on your DVD player. (Only worry about the yellow video cable bit initially). Alternatively, try a different cable type; you'll have some ins and outs that don't use RCA connectors.
Mar 03, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
Sony Playstation 3 (PS3) Console Logo
121 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
