Question about HP Pavilion dv9000z Notebook
No Audio with HDMI connection
Hi there, I have a similar problem. Got my HP to connect with my TV (by pressing Fn F4, but can't seem to get the audio to work. Did you ever find a solution?
Thank you
  • chiefscout Aug 12, 2008
    Got it to work. Thanks so much!
  • 186 Answers
I think I have one for you....
1. Go to Control Panel ---> Sounds and Audio Devices.
2. Click on the Audio tab.
3. In Sound Playback, under Default device select the 'SPDIF Interface' or Digital option.
4. You should be able to hear the sound from TV.
Posted on Aug 11, 2008
Hi there I have a Toshiba CT - 9969 and want to connect my laptop using VGA? What must I do and where do I switch to VGA on the remote? Thank you
connect to TV using VGA port and select device or mode to PC in tv menu. or using remote
press laptop fn +F4
or see display change button in FN buttons .press with or without FN button . if you use HDMI pls cinnect with HDMI cable and in TV pls select HDMI mode in video mode
There is a row of Function keys at the top of the keyboard on every Toshiba notebook. These give you quick access to some useful functions. To activate them, just press the FN button on the keyboard together with the function key to activate the following commands.
press FN+F4
Nov 16, 2016 | Toshiba Computers & Internet
I would like you to tell witch keys i should used to get hp pavilion dv9000 pc lobtop screen to display on a samsung plasma monitor
I'm assuming you are connecting the laptop to the plasma screen with an HDMI cable. If you have done so, then have both the TV and laptop turned on. Log into the laptop with an account. After you have logged in, you can press the function key (Fn) and usually its F4 (the key has a picture of a square, this represents the external display connection) at the same time. The plasma tv should display what is on the laptop.
So, Fn + F4 should work.
May 21, 2011 | HP Pavilion dv9000z Notebook
When i connect my notebook to LCD TV with hdmi port, screen goes black but on TV "No signal" message appear and can`t view the monitor on TV. I have windows XP sp3 on the netbook HP 425
From page 47 of the user manual for the HP 425, "Press fn+f4 to switch the image between the display devices connected to the computer."
Press and hold the "fn" key on the keyboard of the laptop while pressing the F4 key to toggle the image between the laptop screen and the external monitor.
Thanks for using FixYa
Apr 23, 2011 | HEWLETT-PACKARD HP 425 WZ266UT Notebook
How do I get the HDMI connection on my HP Pavilion dv9000 to work. I have a HDMI connection on my Pioneer HD TV but I don't know how to get the connection on my computer to work. It there some trick I...
Normally the computer will detect that you have hooked in the HDMI cable and will automatically send an signal to the HDMI cable. It sounds like the "automagic" didn't work.
What you need to do is press fn+f4 to cycle the display mode to send a signal through the HDMI port. This works in a multi-mode way. You hold down fn and press f4 one time. Don't let go of fn and you should see a mode indicator on the laptop display. Each time you press f4 it will cycle to another mode. Depending on your specific configuration you might need to cycle through VGA first to get to HDMI.
Jan 09, 2010 | HP Pavilion dv9000z Notebook
I have an Acer Aspire 8930G trying to connect to my TV with HDMI
After you connected the HDMI Cable to the TV...Did you press the FN + F4 Key on the keyboard... The first screen you will see is the notebook screen is blank and the TV has got the desktop on top of it...The second time you press the FN + F4 then you will see thedesktop on the notebook and as well as the TV...The third time you press the FN+F4 you will see the desktop on the Notebook...
Aug 15, 2009 | Computers & Internet
Connect computer HDMI to Projection TV HDMI to watch web TV
use a s-video cable or a monitor ext cable and use fn+f4 to switch
pc mon to ext mon.
n.b. f key is usually f4 , models vary.look for square icon on f key.
fn+ that key; thats fn and say f4 pressed together.
Jan 28, 2009 | HP Pavilion dv6000z Notebook
HDMI HP Labtop to Mitsubishi HDMI not working
Easy...first connect the hdmi cable between laptop and tv. Press and hold the 'fn' key on the laptop keyboard - bottom left corner. while holding the fn key, press and release the F4 key. This will toggle the laptop between its multiple display capabilities.
Press and holfn - press and release F4 until you get an image on the big screen.
Enjoy :)
Dec 22, 2008 | HP Pavilion dv7-1130us laptop
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
Hooking up my hp laptop to a sony trinitron tv
Let me explain on how to connect the TV to HP notebook.
There are two ways to connect the TV to the notebook. One is with the S-Video cable and another one is HDMI cable. (If you computer had HDMI port)
Connecting notebook and TV with S-video cable:
You need to get the Svideo cable and connect it to the notebook Svideo port to TV Svideo port and press Fn+ F4 to get the notebook display on the TV.
For the first time pressing the Fn+F4 keys, you will get the display on the TV and there will be no display on the Notebook.
If you press the Fn+F4 for second time, you will get display back to the notebook and Tv screen becomes blank.
By pressing the same keys again will show the display on both the screen.
Samething connecting with the HDMI cable, if your computer had HDMI port.
If you won't get the display on the external screen even after following the correct process, then once you need to reinstall the display driver.
If the issue persists, then you have to check with another cable.
Note: No need to install any software on the notebook to connect the TV to the notebook.
Aug 01, 2008 | HP Pavilion dv6000z Notebook
HDMI connection on HP Pavilion dv9000
try going to windows mobility center & click connect displays
Feb 03, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
332 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
