My rooftop antenna has stopped receiving television signals. It happened after a severe electrical storm. Is there any way to repair it or even to determine what the problem is?
  • vegevick Aug 12, 2008
    What is involved in changing a coaxle cable?
  • 2,071 Answers
Coaxile cable is the cable use to your TV connecting to the antenna its better you change it all cable and clean the connector with a sand paper so proper contact comes out for better signal..
hope this may help
Regards,
VOTIT
Posted on Aug 12, 2008
    Genius:
  • 2,028 Answers
I've had this happen before. I had to run a new cable from the antennae, the lightening burn up the wires in side the cable. You can get the cable at any electronics store (Radio Shack), or at most hardware stores (Home Depot). Try running a new cable from the antennae, this should clear it right up.
Posted on Aug 08, 2008
  • Ryan Rogers
    Ryan Rogers Aug 12, 2008
    You can get the cable with the tv end already attached, so go that route. On the antennae end, some are soldiered, and some are connected using a compression fitting. You will need to inspect the antennae end to see which you have. Soldiered will require heating the old soldier for removal, then resoldier the new exactly as the old. A compression fitting is much easier, and requires loosening a nut. Note how the old is in the fitting, then place the new in, exactly as the old, and retighten the nut.
  • 38 Answers
Try replacing the rotor
motor and its control box, the antenna should be fine. look into sticking a lightning rod on your roof (higher up than the antenna) to prevent future damages to your antenna also. Hope this helps!
  • Josh Hamman
    Josh Hamman Aug 09, 2008
    also, try replacing the wiring as it is probably destroyed
    Master:
  • 623 Answers
It may be your tv tuner,not the antenna
    Master:
  • 521 Answers
It is due to the disturbance of the wirres passig the signals a proper technician can definately clear the problem for you if you yourself want to try this is the option
You could always try an attic install if it doesn't work all you have to do is run the coax from the attic to the outside loacation.
I've got a attic antenna. I get 85-99% on all channels..
If that's vinyl sidding you can hide the cabling under it buy using a unzipping tool.
You can buy coaxial cable with gound wire attached. Just make sure you use a ground block if you don't the electricity may go down the coax.
  • tech expert12 Aug 14, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
JVC HD-56G886 tuner stopped working
My (unfortunate) guess would be the Tuner received a static discharge when you were changing the antennas... this time of the year is bad for static - if you're in a "Winter" climate.
Receivers have a very sensitive FET or MMIC amplifier right inside from the antenna connection to make it better for picking up distant stations.
However, this same "sensitive" amplifier is also prone to being destroyed by even a small static discharge... especially if the tuner had its power turned ON.
Sad to say, it's likely toasted... :-(
(I hope I'm wrong... but you have already tried all other possible solutions)
Jan 12, 2013 | JVC HD-56G886 56" Rear Projection HDTV
Samsung HL-5667W The picture has 5 vertical lines in it that are pink & green with ant input.Also the rest of the pic is grainy & flashing. The internally generated pic is perfect.What is possible...
RF signal you are receiving needs to checked and repaired if you are a using settop box as your RF receiver and it has AV options use them and check how the signal is if directly,if from antenna check cabling if not broken or corroded and check antenna receiver box for corrosion
Oct 14, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung hlp 4663w does not receive off air signal from roof antenna through antenna ports 1 or 2. Get cable signal just fine through same ports. Same antenna works fine on other tvs. Whats the problem and...
If you're in the US, you will no longer get antenna signals because the US has recently switched to digital. The TV you have does not have a digital tuner and you'll need to purchase a digital converter box that converts a band of analog signal to digital.
Feb 03, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Green (power on) light continuously blinking/set won't turn on
This set was designed in such a way that when it is unplugged and plugged back in the LED will blink for around 90 seconds and then stop. During that time you cannot turn the set on. This is the amount of time it takes for the Digital Module to boot up. These units have a problem with some capacitors going bad in the Digital Module and when that happens the LED never stops blinking. You need to contact a qualified repair shop to get it repaired. I have repaired many and the cost is around $250 to $350 depending on where you live. That set is well worth the repair cost.
Jun 02, 2009 | Mitsubishi WS-65613 65" Rear Projection...
I have a digital TV with an outside antenna and rotor.I rcv analog channels w/o any problem.I can rcv channel 19.1 on my TV and on my old TV with a converter box. I have gone to antennaweb.com to get the...
the frequency catcher of the antenna may be weaker then required.to receive the digital channels u can attach a network booster which will solve the problem.
Dec 04, 2008 | Televison & Video
After an electrical storm last night we have lost ITV, Ch 4 etc on Digital, BBC and Sky on freeview are fine. All analogus signals are of very poor quality. Any ideas please?
Electrical Storm normally damage Tuner in TV.
Symptoms in tv like poor analog tv signal reception shows replace TV Tuner.
Regards,
Sep 03, 2008 | Televison & Video
In a electric storm tv would not come back on
you more than likely recieved a surge from a near by strike. you will need an experienced tech to repair the damage, which can often be severe.
Apr 06, 2008 | Televison & Video
RCA P52939 - Can it receive HD-Only signal? Is it Analog-Only?
The P52939 RCA is a analog Standard TV you will need the Digital converter to receive digital signals
Feb 10, 2008 | RCA P52939 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
