Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
External hard drive
Lacie 500 gb making clicking sound. It is not being recognised by My Computer. When connected to PC the lacie seems to stop or slow down other pc programs. have tried disconnecting the power supply from the lacie and reconnectin. No Joy. Seemed to freeze while copying music files from 'C' drive (My documents) to lacie external device.
Any suggestions worth trying?
Jim
  • japben Sep 07, 2008
    I had a power cut while the drive was seeking to restore a digi file - now it just keeps seeking and will not appear on the desktop and non of the utility programs (Diswarrior Drive Genius) see it?
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Posted on Sep 08, 2008
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Disc not recognised by computer, orange light showing on front
Orange light and clicking noise sounds like the hard drive has failed.
The enclosure should still be good so if you can open it and replace the hard driver you will be back in business.
Good luck.
May 29, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie ext hard drive, 500 GB, doesn't show files but 123GB used
you can always recover your files with the program undelete . exe
verry good working tool.
if you are interested
Feb 13, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
When my lacie external hard drive is connected,my
Check your BIOS > StartUp sequence
Maybe the USB boot option has much higher priority that HDD boot. Try exchanging their priority and then reboot, with your external HD connected to pc.
Jan 03, 2010 | LaCie (300951U) 500 GB Hard Drive
Computer cannot recognise the hard drive ;
inside there is a usb and data port attache in hard drive. some time thise port may be damage and also usb cable which we connect on computer may be damage. we came to know after changing two thing ,change one by one to check,
Sep 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I WANT TO OPEN THE LACIE 500 GB HDD AND USE THE HDD IN MY DESK TOP
Go for it. There's a chance the internal drive will be PATA (IDE) but odds are good it's a SATA drive with standard connections.
Make sure your PC has connections for SATA drives, and you'll need to buy a SATA cable since the one in the LaCIE case won't connect from your drive to your motherboard.
Sep 08, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have LaCie 500 GB Exernal Hard Drive. I was transferring some data from my computer into the hard drive. The hard drive fell off and stopped working. When i connect it to power, the power light doesn't...
Sounds like the power supply in the external case has gone bad (or going bad)...
If you have another external case, AND the drive itself is not damaged, you can move the drive to an external case.. Alternately, depending on the connection (IDE/SATA) you can move the drive internally to your computer.
Jul 20, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie HArd drive not accessible
Start > Control Panel > Administrative Tools > Computer Management > Disk Management
Find the drive on the bottom section, right-click it and assign an unused drive letter of your choice. It should then appear in windows explorer.
Jun 30, 2009 | LaCie (300770) 250 GB Hard Drive
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
812 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
