Question about Toshiba 57H82 57" Rear Projection Television
I have a Toshiba 57H82 rear projection tv. It has colored wavy lines on the screen and no picture.
  • Toshiba Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 22, 2011
SOURCE:
My 57h82 picture has picture noise in form of small jagged/wavy lines at edge of objects - particularly noticable for text or numbers. This appears on all channels and with all input sources. How to fix?
Is a common problem. Your hyperboard has failed. You can get a repair kit from www.TvRepairKits.com or buy a used hyperboard - but it will also fail someday unless it has been repaired with better parts than what the factory supplied.
Dec 22, 2010 | Toshiba 57H82 57" Rear Projection...
My Toshiba cinema series HD separates the red & blue color.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Toshiba 57H82 57" Rear Projection...
We have a Toshiba HDTV model number 57H82. It is
Sounds like a bad tuner/decoder on the Qam analog side of things. You can bypass this with a Clear qam converter box or a analog to digital tuner box or simply having this repaired upwards of $200 bucks.
Thanks for using Fixya.com
You're Toshiba Tv Expert.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82- Distortions on the picture screen
You have leky caps in your regulated power
supply they are typ 220 uf 200v and are large
and round next to flyback
Jun 23, 2009 | Toshiba 57H82 57" Rear Projection...
Picture all distorted cold warms up ok
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 06, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 50H82 Wavy Lines - Jittery Picture.
Dont have the manual - sorry - but this is the most likely cause.
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Nov 11, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba, 57h82
Hire a skilled,senior tech willing to rebuild your board....
replace all bad caps.......good as new.................T.
Dec 19, 2007 | Toshiba 57H82 57" Rear Projection...
Wavy picture on all video inputs except component video toshiba 57h82
make sure you replace all the 10uf caps and that the connections are good....
Sep 20, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
109 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
