This camera has a weak capacitor which holds needed voltage to operate your camera. the cost to repair will outweigh the cost of a new replacement
When the camera turns on, it goes through an initialization, and if anything isn't right with the microprocessor, it shuts the camera down. If a new battery didn't help, try cleaning the battery contacts inside the camera with a qtip and alcohol, or a pencil eraser. If that doesn't help, it's probably not a power problem, but it could be a lens issue. The following blog detais the things you can try to fix it:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If none of the steps helps, the camera will have to be serviced. You can take it into a local repair shop, or contact Pentax Support. Make sure you get an estimate first, since repair can be costly.
Good luck, and hope this helps.
Lens extends and opens properly. No lens errors. Could have gotten that advice anywhere.
