Question about D-Link AirPlus DI-524 Wireless Router
Simultaneous wireless connections problem
I have comcast cable, but used to have verizon DSL. When I had everything configured correctly using my DI-524 and verison dsl, it worked fine. But now for some reason using cable modemit doesn't. Let me give you an example.
I can connect (no problems) with my PC using an internal wifi card, but as soon as I try to connect to the net and network with say; a laptop or another PC wirelessly...they cancel out one another continuously, conectuing and reconnecting, one at a time.
Can someone help me out with this problem, I can't figure it out.
  • kwgpc Aug 09, 2008
    But that would mean giving up security features,wouldn't it
  • 2,794 Answers
Reset your router to default settings by holding down on the reset button for 30 seconds.
See if that takes care of the problem.
Posted on Aug 08, 2008
  • Tim Babcock
    Tim Babcock Aug 09, 2008
    You can always reset them back right away. Once you setup a wep encryption key, if any computer were to be in they would be dropped off very quickly.
How to connect inenter by using lan and ftp
To connect to the Internet you need a few extra things aswell as a network card and install the LAN card driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Jun 11, 2011 | Computers & Internet
No internet access with wireless
First of all check the DSL cable must be in WAN port of the linksys router. if it is done then do the following.
Actually DSL modem and Linksys router are conflicting with their IP class. Means DSL and Linksys routers are using the same IP class of 192.168.1.1 or 192.168.0.1.
You must change one's IP class because both are routers and if they having same class they cant communicate. Unplug the WAN cable of the linksys. open browser and put ip 192.168.1.1 or 192.168.0.1 any one which works for u in the address bar. Username and password hopefully be admin admin or just admin and password blank field.
when you access the linksys router configuration page then come to LAN configuration. If there IP is 192.168.1.1 then change it to 192.168.0.1 and if it is 192.168.0.1 then change it to 192.168.1.1 Save configuration and reboot your laptop and plug dsl cable to linksys WAN port.
Hope now this will work.
Regards;
Hasan
Dec 30, 2009 | HP Pavilion dv6000z Notebook
I just got verizon DSL and I want to know how I can hook my Linksys router so it can reconize my laptop
connect the ethernet cable from dsl to router
configure router (on laptop) using supplied software and set security code
search for network on laptop and connect using security code
Sep 27, 2009 | Linksys WRT160N Wireless Router
Macbook and I-touch loses wireless connection with versalink dsl
It sounds like the dsl modem and the gateway should be sync'd in the following way:
1. Turn everything off and disconnect the dsl for a bit. Make sure even the wifi stuff is off.
2. Turn on your gateway and let it cyce up.
3. Plug the dsl ethernet cable into your gateway, and to your phone line, then plug in the power to the dsl.
This will cause the dsl modem to "find" the gateway IP address and connect.
4. Turn everything else back on.
This should eliminate all the drops...
Let me knowhow it goes...
K
Jun 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
D-Link connect to comcast
connect the the ethernet cable to the WAN port of the modem.
the connection should be:
One end of the cable is connected to the modem and the other should be connected at the WAN port of the modem.
Now use another Ethernet cable plug it in on the LAN port1 and the other end to your computer.
Access the configuration page of your router and set the wireless setting inside your DI-624 router.
Dec 10, 2008 | D-Link DIR-625 (790069292637) Wireless...
Using External Wireless Card with an Internal wireless laptop
5fa34b4.jpg this works on it's own. like it is needed to connect to verizon wireless internet. your internal on the other hand is designed to work with a home networking equipment such a wireless router (one that is connected to the internet via DSL / Fiber / Cable / etc).
Jun 19, 2008 | Toshiba Satellite A105 Notebook
Actiontec GT701-WG won't operate wirelessly
In looking on the internet the unit is a DSL gateway. Trying to use it on cable internet is not a real good way to set up your network because I believe the router is waiting for a DSL sync before the services turn on. I would spend the money and pick up a Linksys or Netgear G router, there around $50.
Jun 01, 2008 | Actiontec (GT704WG) Router
D-Link AirPlus DI-524 Wireless Router Logo
44 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
