Printer ip3000 did what you said and went to canon site. downloaded driver file to my documents folder. clicked on this in documents and unzipped file. was then told to go to file setup.exe and double click for installation. where do i find this file and did i really need to download this. as i said after hard drive cleaned up software for printer gone and can't find disk. many, many, thankx as i'm not good at this and the kids need the printer
  • 398 Answers
When you unzipped the file there was a destination folder for it, You should see that folder in my documents, if not unzip it again, and designate a destination like in my music or my videos, anywhere that you find it after unzip. Then go to that folder and open it, and the exe stuff will be there. Just double click and it should install what you need.
Posted on Aug 08, 2008
Go to
Select Downloads
Select Office/Production
On next page from the dropdown select Office/Production products again
Next page Select Networked Office Systems/Copiers
Next Page select Color ImageRunner Series
Next Page Select Color ImageRunner Series
From List select Color Image Runner Irc-3200
From the choices select the driver needed. PCL or PS (postscript)
Select either Setup or INF.
If Setup or INF file. Download the zipped file. Create a folder on desktop or downloads. Call it Canon Copier or whatever. Download the zipped file to this folder. Go to the folder you downloaded the zipped file to and double click on the file. When Win-Zip started and asks where you want the file un-zipped to enter a period (.) this will unzip the file to the folder you created.
Once the file is un-zipped if you downloaded the setup file run setup exe.
At somepoint in the setup process you will be asked which port you want to use. You will need the IP Address of the copier ( which can be obtained by pressing the additional Functions key on the copier, selecting report settings, selecting Network and print report. If the IP address needs to changed select additional functions again, Select System settings Key, Network settings key, TCP/IP settings, Check or Set IP Address here or select DHCP to get new address. Repower the copier if any changes are made.
At the which port to use select New Port, select Standard TCP/IP port and create new port. Enter IP address in the new port window.
If using INF file after INF is unzipped. Go to Printers folder and select create New Printer. Follow Printer Wizard. Create New Standard TCP/IP port. When the Wizard Asks for Driver, select have Disk and browse to the folder you created and click the unzipped file and continue clicking until the file installs.
Mar 20, 2010 | Canon imageRUNNER C3200 Copier
I just bought a Ricoh Aficio SPC232SF multifunction printer. The CD it came with does not work with Windows 7. I downloaded the documents labeled ''drivers'' from the website, but there were no drivers in...
Well you do not need to return the printer because the files you have downloaded are drivers just they are installing on other way.
If you follow the explanation in the text below it will be very easy.
First as you say i think that you had already unzip the .exe file or if you did not follow the next steps:
1. Create one folder on the desktop named as you want or as the name of the printer for you after easy to find it.
2. double click on the " r41337en.exe " file that you had downloaded from the web site and click browse to find the folder that you had previously created on your desktop when you will locate the folder click unzip and after the message "successfully unzipped files " close the self executing program and see do in the folder are some files if there are some files, continue with the next step.
3. Click on the " Start " menu,
from the desktop in the left down corner,
and then click on "devices and printers"(doubleclick)
4. One window will open and than in the upper left corner you will find "add printer", click that button and it will appear a "add printer wizard" , click twice on the button "next" and select up the port you will use for the printer (do it will be a USB connection or with network cable is up to yours notion)and after you will select the type of connection click "next" again.
5. On the wizard on the right side has a button named "have disc" click on it,
it will appear window named " install from disc " than click the button named "browse" and then browse the folder which you had previously created on the desktop, in which you had unzip the files for the printer installation.
6. When you will locate the folder click on it with double click, then will apper folder named " DISC 1" click and on it with double click and then will appear file named " PCL6.INF " click on the file with double click ,
7. Then will appear a window named,
" install form disc" click on the button "OK" ,
then click on the button "next" three times and then click "Finish "
That is all the printer is now installed and ready for use.
Please answer do this was helpful for i to know do i need to post some more information
If you need something else please ask
Jan 08, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Where can i`am download the installer co`z i`am,lost my cd
assuming that u r a professional..along wid the company, there will b a list of such site n driver download links if u search by the model name on a search engine like google..
download them onto a location; if the driver is in a zip format, unzip it,if itz in .exe form, just run it; if done manually it'll ask for the correct driver and location; relocate the path and a .inf file (wat it'll ask for)..
however try this:
but always better to consult system admin/vendor....
Oct 31, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
DELL 1600n drivers for 2003 Server (Network Scan)
  1. Click the file name below to download the driver:
    new_note.jpg Note: By downloading, you accept the terms of the Dell Software License Agreement.
  1. Click the Save button.
  2. On the Save As: window, verify that the R165289.EXE file name is listed in the File name: box, and then click the Save button.
  3. On the File saved window, click the OK button.
Back to Top
» Install the Drivers, Files, or Utilities
  1. Locate the file. It is usually on the Desktop or in the My Documents folder.
  2. Double-click the file icon and click Continue.
  3. In the Select the folder where you want to unzip the files to window, click OK.
  4. If a message appears asking to overwrite the folder, click Yes to All. If a message appears asking to create a folder, click Yes.
  5. In the All files were successfully unzipped window, click OK.
  6. Follow the prompts that appear to install the driver.
  7. If prompted to restart your system, click OK.
Nov 26, 2008 | Dell 1600n All-In-One Laser Printer
Can't install Canon ImageCLASS D780? Please help
I just checked on the Canon USA site here, and selected Wndows XP as the OS. The driver presented shows Windows Vista in the file name (D700_PrtDriverV110_WinVista_EN.exe), but the next screen shows that it is compatible with Windows 2000, Windows XP, and Windows Vista. I would try uninstalling (if it is installed) whatever driver you currently have installed for your D780, then download and install this driver. Leave the unit turned off until the installation program asks you to connect/turn it on.
Sep 14, 2008 | Canon imageCLASS D780 All-In-One Laser...
You can download the drivers from the HP site.
Go to , click on the drivers and download section, put in the information about your printer, and OS.
Download the file (just make note of where you download it to).
Once the download is complete, close the site. Go to the folder you saved the file to, double click to unzip it, here again, make note of where it unzips to.
Go to your Add Printer wizard, and when it asks which printer, click "Have Disk" and point it at the file you unzipped.
Aug 23, 2008 | Computers & Internet
Well first off, you're going to have to download the Vista drivers for the 2610 from the HP site.
Once you download them, unzip the file (just doulbe click it to unzip) and make note of where it unzipped to (it will say something like C:\drivers\xxxx
The go to your printer window.
Click the "Add printer" and local install. When it asks about drivers (what kind of printer you have) click "Have Disk" and point it at the folder the download unzipped to.
That's about it.
You don't need the install disk.
In some cases, the download file will be a complete install routine. In that case, once you unzip it, sometimes it will go right into the install, in other instances, you have to look at the folder it unzipped to, and look for a setup.exe file
Aug 23, 2008 | HP Office Equipment & Supplies
Lost start up disc for canon printer Canon iP3000 Series
Please click on this link:
Once opened, there is a dropdown menu to the right. Click it & choose you're operating system. Creat a folder on you're desktop & name it Cannon. Download the driver software into that folder. Run the downloaded ip3000xp180ausZ.exe file.(this is for Win XP).
Good Luck!
Jun 13, 2008 | Canon Office Equipment & Supplies
Lexmark X5150 driver download
please try these steps
  1. Reboot the PC.
  2. Make sure the printer is selected as the default printer in the Printers folder and try to print again.
  3. If printing fails, you will need to download the printer driver again. To do this:
  4. Create a folder on your desktop and call it Lexmark.
  5. Go to our Drivers & Downloads center. Note: The name of this page/site may be slightly different in your region/country.
  6. Click Printer Driver.
  7. Select the Related Product Name from the drop-down menu.
  8. Select your Operating System from the drop-down menu.
  9. Select the desired Language from the drop-down menu.
  10. Select the latest Driver File and click on the File Name to detach it to the Lexmark folder on your desktop. Wait for the download to complete.
    Important: Make sure any copies of the driver from earlier installations are uninstalled before you install the downloaded version.
  11. Install the downloaded driver as follows:
  12. Open the Lexmark folder and double-click on the downloaded file.
  13. When the WinZip Self-Extractor screen appears, click on When done unzipping file open: <the printer file name>. (The printer file name will appear beneath this option.)
  14. Click Unzip. The installation program should autorun. Follow the on-screen prompts to install the printer.
  15. If the installation program does not autorun, locate the newly created LXK___ folder for Setup.exe and double-click on it. An installation program will run. Follow the on-screen prompts.
  16. If you are prompted to install the printer for all users, click Yes.
  17. When the installation is complete, restart the PC.
Jan 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
42 people viewed this question
