Question about Video Game Consoles & Games
Our playstation2 is freezing in the 2 player mode of MLB08 The Show Can you help?
  • keng125 Aug 08, 2008
    We just bought it and we have already replaced it once. This is the second CD Any other suggestions?
    Master:
  • 623 Answers
Defective cd
Posted on Aug 08, 2008
  • Anonymous Aug 08, 2008
    lens alignment on rails,it could be dirty,needs grease
  • Anonymous Aug 09, 2008
    unfortunately your lens is bad.you need to take it to a technician...if its the game then all mlb08 is defective and that cant be...
SOURCE:
Sandisk mp3 freezes
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 04, 2010 | SanDisk Sansa e200 MP3 Player
Tip
For Version 2 Sansa E200 Series and Version 2 Sansa C200 Series
As you have notice, these version of player will not have the USB Mode / Mode ( FOr Rhapsody Players ) and / USB for sansa C200 series. If you want to have your player detected by the computer as a removable disc drive or as a MSC drive you can perform this easy steps.
For Sansa E200 Players and C200 version 2 Players.
1. Enable the Hold Switched for it to show a red color.
2. Press and Hold the Rewind button the " << " then connect to the computer.
3. Connect the player to the computer and dont let go of the Rewind Button " << " , you will notice that the player would be detected as a removable drsc drive in the My Computer Window.
*For Load Main Image Failed Problems and player Freezing on the Refresh Database Screen will be post later*
on Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
Re MLB08 the show - my ps2 freezes up at the end of a game, Why?
could be a hairline scratch or similar try spraying with polish cleaning with soft duster, leave to dry for at least 5 mins then try loading
May 19, 2009 | Sony PlayStation 2 (PS2) Console
Playstation2 player can't read playstation one games.
the ps2 is supposed to read all the same region PS1 games so you shouldnt be having a problem. Es : a PAL ps2 can read PAL ps1 games
Mar 24, 2009 | Sony PlayStation 2 (PS2) Console
Game freeze
Blow it out with a can of air also take it a part an clean all the dust out.
Dec 28, 2008 | Sony PlayStation 2 (PS2) Console
My playstation2
This problem occurs when there is some problem with the PS2 cooling system, If you are inclined to open the console and it is out of warranty, it's a good idea to perform some routine cleaning and check for areas cooling fan... if there is most likely a LOT of dust in the system... or that may need re-greasing, and check for Cooling Fan cable/soket are plug in as well.
Hope this be of some help/idea. Pls post back should you need additional information, and pls show Show your Appreciation, it will help other USER. http://e-arena.blogspot.com.
Nov 06, 2008 | Sony PlayStation 2 (PS2) Console
Playstation2 freezing up
when playing...3hours on 30 mins off...your laser is overheating
Aug 10, 2008 | Sony PlayStation 2 (PS2) Console
Rock band won't play on my playstation2 slimline
ughh my rock band disc loads the playstation2 screen and when the black is suppose to load it its doesnt go any farther and the playstation makes a beeping sound :( help!
Aug 02, 2008 | Sony PlayStation 2 (PS2) Console
My playstation won't show picture or play sound!!! going nuts on spring break!
Your playstation2 has almost lost it edge in circuit electronics. Especially the michrochips involve in video, sound and power supply is already burn out its link. Due to over use time of the unit you play. From time to time michrochips burn out their IC link which cause the problems we encounter.
PinoyBisdak
Apr 03, 2008 | Sony PlayStation 2 (PS2) Console
My PS-2 Slim always show " Please insert Plyastation or Playstation2 Format disc "
see if the cd is NTCS/UC,NTSC/J or PAL and see what is your ps2 designation see at the back you will see if it is NTSC/UC.
hope this helps.
Nov 14, 2007 | Sony PlayStation 2 Slimline Console
Open Questions:
Just purchased a TTX Tech wireless PS3 controller that comes with a USB key fob that connects to one of the front USB ports of my PS3 console. I have successfully synced it to my PS3 only issue I'm having is how drastically different the configuration is from the usual sixaxis controllers. I noticed between the 2 controllers there are 2 clear differences amongst them. 1 being the trigger buttons are not the same and that the circular circumference for the analog sticks are alittle bit different in size. Basically comparing the size of a 25cent coin to a 5cent coin. I'm assuming because of the analog having less of a left to right and or a up and down travelling distance due to the difference of having a smaller analog circle that it could very well change the sensitivity aspects in the game of choice (COD Black ops 2) but I mean the difference between the two controllers is beyond noticeable I've experimented with lowering the sensitivity level from what was set when using the sixaxis controller compared to when using the TTX Tech controller. For example using the sixaxis I'm set to 13 for my sensitivity but when switching to the TTX Tech to become even close to having the same feel and view while using it in comparison to the sixaxis i have had to lower my sensitivity level to an 11 or a 10 instead of the 13 and yet it still is quite noticeably different from my sixaxis controller. Also I've found that the right analog for the TTX Tech is extremely sensitive gently applying upward downward and also side to side pressure on the analog causes a significantly noticeable jump or jolt that seems to never differ in speed regardless as to what has been set for the sensitivity level in game settings. In a nut shell basically I'm asking if anyone else has noticed these things I'm experiencing and if there may be a configuration manual or program that could some how configure the TTX Tech controller to act more as if it were a sixaxis controller in the aspects of the analog sensitivities and responding timing. Yes of course a new controller with a different shape and or feel will make for a "getting used to it" experience which does generally occur after a time period of using said controller more and more often. I am more or less meaning whether or not the smoothness and or the rythem you would have with one controller be more similar with one another. If anyone is a gamer and has gone from using a normal typical original PS3 controller and unfortunately having it be no longer able to be used to play games and switching to the TTX Tech controller immediately afterwards I'm sure will know exactly what I am trying to explain. Appreciate any insight and or knowledge towards my inquiry. Thank you kindly for the assistance and of course take it easy or take it any way you can get it :)
Oct 19, 2019 | The Video Game Consoles & Games
Video Game Consoles & Games Logo
19 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
