Question about Samsung Televison & Video
Samsung sp-61j5hf 156cm rear projection tv convergence problem, gone through manual convergence and aligned there, but it is all over the place around the screen with no pattern to which way the convergence is out
Buy a real tv
Posted on Oct 20, 2008
I have a Mitsu ~ HDTV 1080 #65511 all the colors are out of wack. I can not find a place to align them and no longer have the manual ..
Tv have colors lines R,G,B mis alignments,have colors shadows picture or 3D pictures look alike?Tv have problems known as a convergence pictures problems.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too,this parts on the convergence board must have be replaced.To fixed the convergence board to solved tv convergence pictures problems.The shops will cost u like $300-350 for parts and labors.
Jul 26, 2011 | Mitsubishi WS-55809 55" Rear Projection...
Our tv just started having a fuzzy image and the auto focus function aborts during the red color alignment. is there a manual alignment I can do to fix it.
What does this fuzzy image look like? Does it have ghosting shadows. Of course it is possible to align red manually from the convergence menu. But first lets confirm that it is indeed a convergence related problem.
Aug 18, 2010 | Samsung HCL552W 55" Rear Projection...
I have Samsung SP42W5HF rear projection tv and
You have either a bad convergence IC on the power supply/convergence board or the whole board is bad and needs to be replaced along with doing a Full Convergence Alignment by a very experienced tech.
Apr 09, 2010 | Samsung Televison & Video
Green out of alignment on samsung rear projection tv
Hi luke I am in the uk and not familiar with this set is it a three tubed crt television or an lcd projector type .. either way what you are descibing is convergence ( three primary colour guns all pointing at the same spot in a nutshell ) in the case of a crt projection tv three tubes one red one green one blue .. there should be a convergence pattern in the menu to re set the convergence via the remote check the manual . If it isn't adjustable you may have a scan coil fault or a tube ie : green with low emission check the green colour gun transistor and associated circuit for leaky caps resistors that have changed value or transistor leakage .. and don't forget the ever popular dry joints on the scan coil plugs .. hope this helps Vortash
May 29, 2009 | Samsung HCL4715W 47" Rear Projection...
Convergence problem, blue ghosts
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung rear screen projection TV issue
Symptom: convergence goes way off intermittently
Cause: DP12 or DP13
Contact me if you need the full repair manual for parts location.
billyjones@fletchersite.com
Jun 14, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Samsung HCN4226W Rear Projection TV
You can get the convergence board by clicking here.
The service manual you might buy it from the same place.
May 23, 2008 | Samsung HCN4226W 42" Rear Projection...
Now What???
I want to get this straight are you saying that you cant align them
and this is your focus problem or you have two problems that you cant get the convergence and the focus?
it might have been easier just to have the board replaced...
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Jan 28, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung rear projection tv
It probably is see if you can align the convergence manually or auto if available, you can order just the convergence ic's or the convergence amp board, whichever you prefer. check pricing and availability. also check Blue crt for faded picture, usually dirty crt fluid, makes picture dark and discoloured. If it is you may need to replace the blue crt also. this gets a little expensive, again check pricing hope this gets you started RFT
Jan 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
139 people viewed this question
Henry  Thomas
Henry Thomas
