Question about Compaq Computers & Internet
I am using Windows 98 in conjunction with compaq Presario 5170,(yes I know it's antique but I like it) and until recently every thing was hunky dory but as of late it seems my surfboard 5100 which is connected to cable is having problems in the fact it sometimes disconnects itself from cable and I have to disconnect the power source and of course the incoming cable and reconnect to get the thing to work. One more thing that may be causing problem. I have purchased a new Dell with all the bells and whistles and have it in another room and am using a NETGEAR wireless device for use with old machine and when it is working it works great but when my Presario goes out naturally the Dell goes out also. I have a cable running to my new Dell from outside as I do my older machine but do not have the cable hooked up instead using the wireless device. The wireless device is a WNR834b-v2 device made by NeTGEAR and as I seaid works great as long as my SB5100 is working. I purchased a new SB5120 thinking that might solve my problem but it doesn't work at all although all the lights come on indicating it is hooked onto cable as well as power but my machine doesn't recognize it......please help....Bill Clark billclrk7@aol.com
    Brigadier General:
  • 6,966 Answers
A couple of suggestions:
  • Pls make sure that there is only one (1) DHCP enabled/active; and/or
  • use static IP addresses specially with the Win98 machine. Do the same whether any of the machine is wired or wireless;
  • disable any WEP or WPA security, if you have to, use MAC filtering;
  • download, install and configure DRTCP, here is a nice tutorial.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 08, 2008
How or what do i need to connect internet i have router (2wire) from AT&T for wireless laptop but now i bought a desktop an compaq presario 5000 with windows 98
You need a Wireless adapter for the Compaq desktop. But with Win98, it will be almost impossible to find one that will work in your Compaq. Everything out there requires at least WIN XP.
Best thing to do is to use an Cat5 Ethernet cable and connect the Desktop to the 2Wire.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 10, 2011 | Compaq Presario 5000 PC Desktop
I have a compaq presario 7470 PC which currently has windows 98, Iwant to know how can i update it with windows 7 and how muche it'll cost?
Generally the specs for Windows XP machines are good enough for upgrading to Windows 7 without too much cost.
But, Windows 98 was a bit further back in the history of Windows.
You can go to Microsoft.com and use an upgrade advisor to see if Windows 7 will work on your machine.
And, they'll tell you the cost.
Aug 01, 2010 | Compaq Presario 7470 (163881-004) PC...
My old compaq presario wont read my scan disc
Can you use that port to read any other device?What operating system are you using?Did it work previously?Windows 98 you will have to install drivers.Chances are that old computer has a usb 1.0 so it might not work.However try another device in that port or any usb port on the computer to see if any ports are working.Does your scan disk work on another computer.Have you done a windows update recently.Make sure you try all the above.
Good luck
Sep 17, 2009 | Compaq Computers & Internet
Recently repaired compaq presario laptop has startup issues
******** and your laptop this link is full of **** do u want if yes bring your sister and when i **** her then i will till you what to do ******** man
john
Jun 21, 2009 | Compaq Presario M2000 Notebook
Supposed to have 20 GB of memory, only have 1.99GB
Use windows 98 to make a rescue disk (3 1/2 floppy)
use that emergency disk to repartition and format the hard drive. You can probley use fat16.
Mar 11, 2009 | Compaq Presario 5000 PC Desktop
How do I start fresh with a used laptop?
Reinstall windows by running the XP or Vista CD. If you don't have windows CD then you may get a retail version from any local computer store.
go to www.windowsreinstall.com for instructions on how to reinstall windows.
Oct 05, 2008 | Compaq Presario 2538CL Notebook
Compaq Presario 5102US downloading Windows 98
If U already have 98 on the pc, R U trying to have dual boot, recover, or reload 98 instead of 98ME?
The disk U R using is a recovery disk and U will still need the 98 cd to reload. The disk is for repairing or reloading the 98 system and I would suggest that U learn how to use the command structure first before attempting a system repair.
Please explain what the problem is and what U want the system to do. We R very happy to help U get to where U want to go.
Jun 08, 2008 | Compaq Presario 5000 PC Desktop
Device not being recognised - USB device not recognised...
Are you running windows media player on Vista, if so I'm having same problem. Appears one needs Windows XP, which is rather annoying..
Jan 31, 2008 | Samsung YH-925 MP3 Player
Cant play cds
Easy peasy (for me at least).
Disconnect the battery, then...
... reconnect the battery
Just done it to mine - all hunky dory.
The CD 'rebooted' - equivalent to turning a PC off and on again!
Delighted to save the time and expense of visiting a garage!
Nov 09, 2007 | Pioneer CDX-FM687 6-Disc CD Changer
Computers & Internet Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
