I have just recharged device. The buttons along the bottom will take me to calendar, contacts, home, etc. but when I attempt to navigate with the stylus, it isn't working. I can't use to OK or start menu.
The Axim touch screen is extremely sensitive to the placement of the protecting plastic sheet. Check that the the plastic sheet is oriented correctly - the small bended corners must bend downwards. If that wasn't the problem then remove the protection sheet and pick gently directly on the screen with the stylus to see if you get a response. Most often this is due to a problem with the screen protecting plastic sheet.
To control sync settings for the device, follow these steps:
Android 4.0 / 4.1 / 4.2
Android 2.1 / 2.2 / 2.3
Android 1.5 / 1.6
Fully charge your iPod touch to prevent draining your battery during the factory reset.
Touch "Settings" on the device's Home screen.
Select "General" from the "Settings" menu.
Choose "Reset."
Select "Erase All Content and Settings." A confirmation window pops up on the bottom of the screen.
Touch the red confirmation button on the bottom of the screen.
hope this helps
If
your phone freezes, hangs up unexpectedly, vibrates continuously ,touch screen
wont respond or in other similar ways doesn't perform as it should, this can
often be solved by performing a software update. Software may perform
incorrectly for many reasons without there being a fault in the phone. Some
problems may be fixed by re-updating your current software, while others may
require installing a new software version.
To
keep your phone performing at its best, it's a good idea to perform a software
update regularly. You might not always notice what an update has done, but it
can prevent future problems.
To
update or reinstall the software please go to nearest authorized service centre
of your mobile make and they will update or reinstall the software as required.
Note:
Reinstalling the software will delete all the content in your phone like
contacts, calendar entry etc.
Thank You
It comes on and I can use all buttons on bottom but I can use touch screen it just doesnt work
i tried changing the plastic sheets too..bt its nt working
I'm having the exact same issue on an Axim X50v. Soft resets do nothing.
