Scanner software does not ask or i would have taken that step. but full install does not help problem
How can i install scanner driver
Posted on Apr 16, 2009
SOURCE:
How do I scan multiple pages to one file using a deskjet 2512 printer/scanner
On the control panel, select scan to computer and choose PDF.
If you are using the sheet feeder, it will scan all pages and create one file with them all.
OR
If you're using a scanner glass, i.e. one page at a time, when the first page finishes scanning, you will get a message asking if you have another - answer YES and follow the instructions (basically that means place next page on scanner glass and hit OK/Continue). Rinse and repeat until you've scanned all pages then answer NO.
You should find a PDF file in your HP Scan Folder usually named "scan.pdf" unless you've changed the settings. (If there is/are already scanned files in that folder, they will have consecutive numbers, e.g. "scan001.pdf" "scan002.pdf" etc
Sep 25, 2018 | HP DeskJet Office Equipment & Supplies
Acer 640 p xp driver not found
Hi dsdss
For this driver to work in XP you must install the MiraScan software then install the scanner manually.
Step 1. Download MiraScan v3.424 from the web :
Mirascan_v3424p.exe
Step 2. Unzip and install the Mira Scan driver that you just downloaded. After installation , system will suggest you to add a scanner
Step 3. Then, add an imaging device
Step 4. Then the Scanner and Camera Installation Wizard comes up. Click Next at the bottom.
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says Manufacturer and then click on EPPSCANNER and where it says Model it should say color flatbedscanner. Make sure it is highlighted, also. Click on Next at the bottom.
Best regards ,
fanaudi .
May 25, 2011 | Acer ScanPrisa 640P Flatbed Scanner
I have ricoh Aficio MP 1600L PCL 6 network printer (print,copier, scanner) i can print copy but unable to use scanner from my pc. my pc have win 7 professional 32bit OS. the scanner driver & utility CD...
Use the network scanner. It is easier for the users and is much better.
Open the browser writes the IP hosts is then just create new users with their own folder paths (previously shared of course).
If you do not have technical training i beliave it will not be easy for you to do it.
Try the chat and ask for help from a specialist. I'd like to help but still can not chat
Feb 11, 2011 | Ricoh Aficio MP 1600L Black and White...
After installing the software then connecting the scanner my computer boots to desktop then shuts off repeatedly.
Hi
The drivers you installed for the scanner are causing your problem,you need to remove them.Make sure the scanner is disconnected from the computer for this.
Start your machine and right after the POST screen,before the Windows startup screen,tap the F8 key repeatedly until your start options screen comes up.
Try booting with the "Last known good configuration" option first.If Windows starts up and functions normally then it worked and has taken you back to right before you installed the software.If not,we'll restart and go through the F8 routine again.
This time,use the "Boot in Safe Mode" option.If you're not familiar with safe mode everything will look really big,that's normal.Go to Start-Programs-All Programs-Accessories-System Tools-System Restore.Start sys. restore and follow along until it asks you which restore point you want to use.Look for a point before you installed the scanner and pick that.
It takes a while to restore,and it will restart your computer at some point.And hopefully after that everything will be normal again.
Post back and let me know what happens with what you have so far.If none of that works there are other options,but those are the ones to start with.I'll be here.
If the steps above work,would youplease rate my post?
Bob
Aug 18, 2010 | HP ScanJet 5100C Flatbed Scanner
Virus affective
For the removal of spyware infection in such cases follow these steps :
Step 1 . Turn off your computer.
Step 2. Press power button to turn it on and immediately start pressing F8 key. It will show you different modes like Safe mode, Safe mode with networking etc etc.
Step 3 . From there select safe mode with networking.
Step 4. Enter your password on windows login screen.
Step 5. It will ask you to continue in safe mode click on yes.
Step 6. Download free version of Malewarebytes from http://www.itechguru.in/Download%20Links/Download%20Links.htm
Step 7 . Install it and update it from update tag >> check for updates.
Step 8. After that go to tag scanner and perform full scan.
Step 9. When scan complete click on show result and then click on remove selected.
Step 10. After removal it will ask you to restart your computer. Restart once.
And enjoy Virus/Spyware free environment.
You can also download other best antivirus softwares also from this link.
iTechGuru
www.itechguru.in
Mar 06, 2010 | Symantec Norton Antivirus 2010 Full...
Need to find a free download to install
Instructions for installing Acer brand parallel port scanners in Windows XP:
Step 1. Download MiraScan v3.424 from the web : Mirascan_v3424p.exe
Note: For additional screen shots of this procedure and installation procedures, please read the pdf file posted here: scpinwxp-eng.pdf
The Screenshots show to be for Mirascan v3.423 but procedure is same for v3.424
Note: Adobe Acrobat Reader is required to view or print this file.
SOURCE : http://forums.driverguide.com/showthread.php?t=35623
Originally written by Jerry K 12-03-2007
Oct 13, 2009 | AcerScan Prisa 340P Flatbed Scanner
Print shop is not installing
Do the following to re-install it again
Step 1. Go to your start menu and type into the SEARCH box RUN>a dialog box would come up
Step 2: Type REGEDIT>click on continue when it asks you to.
Step 3: Click the arrow beside HKEY_LOCAL_MACHINE>Click software and delete Print Shop> Try Installing the software again.
Regards.
Aug 28, 2009 | Dell The Print Shop 20 Deluxe for PC
I need a driver soft ware to work with windows xpsp2 for acerscan prisa 310p email: [email protected]
Instructions for installing Acer brand parallel port scanners in Windowsmag-glass_10x10.gif XP:
Mirascan_v3424p.exe
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says "Manufacturer" and then click on EPPSCANNER and where it says "Model" it should say color flatbedscanner. Make sure it is highlighted, also. Click on Next at the bottom.
scpinwxp-eng.pdf
Note: not all XP systems will work with parallel port scanners. If the procedure doesn't work for you, then you must obtain a newer USB type scanner.
Mar 22, 2009 | AcerScan Prisa 620U Flatbed Scanner
Driver for Acer Vuego 610P
Mirascan_v3424p.exe
Note: For additional of this procedure and installation procedures, please read the pdf file posted here:
scpinwxp-eng.pdf
from Vuego Scan
Nov 26, 2008 | AcerScan 610P Flatbed Scanner
I need umax astra 3400 scanner software
Have found information on umax.com !
Solution is VistaScan X CD only for Windows XP, when you use it withaout Internet-Connection (local)
http://www.umax.com/vistascan-x-cd/
Or: VueScan also for Windows 10
https://www.hamrick.com/de/vuescan/umax-astra-3400-treiber.html
But you've some costs...
Nov 14, 2008 | Umax Astra 3400 Flatbed Scanner
Open Questions:
46 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
