Question about Sony Handycam DCR-TRV19 Mini DV Digital Camcorder
Blinking arrow and numbers, won't eject, play, rewind, fastforward
My cam won't play, rewind, fastforward. Nor the tape be ejected. and there's a blinking yellow arrow at the middle of the screen. and on the upper right where numbers that tells the recording time you still have, its also blinking. help please. its important,
    Master:
  • 763 Answers
Your camcorder must be broken. a specialist should work on that. go to your nearest technician to help you with. they have a tools for that. hope that helps!
CHARCOIS
Posted on Aug 09, 2008
After the tape rewinds and then I push the eject button, the tape doesn't rewind back into the cassette before ejecting.
This should also be happening when you just eject the cassette without rewinding.
NOT KNOWING THE BRAND, MODEL, OR NUMBER WE CAN ONLY DO SO MUCH!!!!
Best guess is a belt needs to be replaced.
Sep 19, 2016 | Televison & Video
Close when play vcr
Problem in the mechanism that moves the tape in play,ff,rewind and also winds tape back into cassette and ejects it.
Likely a bad or worn belt or drive idler(rubber).
Nov 04, 2012 | Televison & Video
My VHS tape is stuck and won't eject or plsy
The transport mechanism ff/rewinds and drives the tape back into the cassette when eject is used.
Most likely a bad belt or the drive idler wheel (rubber or geared). Unit would have to be taken apart to "see" what is not happening.
Oct 22, 2012 | Televison & Video
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
When turning on to vcr or camera, camera beeps repeatly
Sounds like the camera ATE THE TAPE will not eject,fastforward, or rewind.. This will need to be repaired , worse case a belt slipped or something got misalligned inside, I would recommend a camera shop so you can save the tape otherwise digging into this yourself could stirr up more issues in the long run. Please do be considerate of facts here that we cannot see your unit and this error is because the tape got ATE or something got jammed.
Thanks please do leave some feedback and ratings for your free answer today.
May 29, 2010 | Sony Handycam DCR-HC14E Mini DV Digital...
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
May 24, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
Tape deck won't play
my machine not working problem is play, fd,rw, is not working all three led of rec,pause,play led is blinking
Nov 05, 2008 | Tascam Audio Players & Recorders
Emerson EWR20V4
this is more of a belt problem, look for a worned belt.
May 16, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Apr 04, 2006 | JVC HR-J461MS VHS VCR
Sony Handycam DCR-TRV19 Mini DV Digital Camcorder Logo
311 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
