Sounds like your motor is getting hot, shutting down to cool off and coming back on. This is a motor that will have to be replaced. On some models the only other thing is could be would be the thermal link that is usually located on the back of the dryer. This would definitely be the cheaper part to replace. If possible, jumper around this thermal link, if it still does the same thing you will more than likely have to replace the motor. Good luck I hope this helps.
Good Morning friend, thank you for your post!
From my understanding your Frigidaire dryer, LEQ1442ES1, will run and then shut down after three or four minutes. I would recommend a reset on your dryer which you can do by unplugging your power cord for roughly ten minutes.
If that does not correct the issue it sounds like a potential problem with your control panel or a sensor. I would suggest having a professional come out and repair your appliance to avoid any unnecessary part purchases. -Matt
