When my electric power goes off from storm, etc; my hp psc 2110 comes back on and makes a clicking noise. I then says warming up. After that when trying to copy it says busy. I have turned off, unplugged, shut down my computer to no avail. Dorothy Deifenbaugh dotjane@frontiernet.net
  • dotjane Aug 08, 2008
    No, so I will take it to a repairman and if it is junk, I'll buy a new printer. Thanks anyway.
    Dorothy Deifenbaugh
  • 6,487 Answers
You may try resetting it first follow this:
Try a full reset by holding down cancel and right arrow button while plugging in the power cord.
If the reset doesn't resolve the problem, I speculate that there is an electonic failure, in which case the printer is scrap, you may take it to a repair center near you or call Hp for repair and replacement if still under warranty..
Hope that helps..........
Posted on Aug 08, 2008
    Master:
  • 521 Answers
Its a circuit board error you have to get it repaired
  • tech expert12 Aug 08, 2008
    try changing thr adapter wire and check
I have an hp psc 2110. I made some enlarged
Some basic steps to begin with:
1. Disconnect the printer from the computer and power off then back on. In some cases the problem can be caused by the print spooler on the computer.
2. If the problem persists, power off the printer and remove the power adapter. Leave the printer sit for 10 minutes or so, allowing the internal memory to clear, After which you should hook the printer back up and reconnect to the computer.
Finally determine if the printer is being recognized, on vista or windows 7 you can do this by clicking 'start' >> 'devices and printers'... or on xp 'start' >> 'control panel' >> 'printers and faxes'
If it is not listed as connected on the list (ie. offline) try uninstalling the printer and rerunning the drivers.
//halfs
May 25, 2010 | HP PSC 2110 All-In-One InkJet Printer
Right when i turn it on it makes noise hp psc 2110
Dose it work?
My hp 750 dose this and even talks when not working.
You can get HP Print Diagnostic Utility software which will fix most hp printers issues.
www.hpsupport.com
R Miss Brooks
Sep 02, 2009 | HP PSC 2110 Color Printer
When you turn on the printer it makes a noise like it is trying to calibrate itself and something is stuck. It will not respond to any function on the printer. I have tried disconnecting the electricity to...
look for any obstructions, things often will fall into the printer, or sometimes the plastic gears, or a tab, etc... is broken, sometimes at a greater expense to repair, DEPENDING on what part is broken, but it sounds like a mechanical failure from the descrption
May 15, 2009 | HP PSC 2110 All-In-One InkJet Printer
Copy problem w/ Windows Vista
For a complete set of instructions on copying with your printer, please click here
If that doesn't get you there, let me know the specific error you're getting and we'll sort it out!
Apr 20, 2009 | HP PSC 2110 All-In-One InkJet Printer
Hp psc 2110 copy problem stuck warming up & scanner bar get stuck
The scanner carret belt might be too loose, so the printer cannot pass through the self-test. Try tightening it a little bit. Also you have to either repair the nobs or solder it.
Feb 14, 2009 | HP PSC 2110 All-In-One InkJet Printer
Hp psc 2110 incorrect ink cartridge message.
Hi plabonne,
I hopped out to HP's support site for stats on your cartridge and found some info at this link:
http://www.shopping.hp.com/webapp/shopping/supplies_model.do?product_code=C8648A&jumpid=oc_R1002_USENC-002_HP%20PSC%202110%20All-in-One%20Printer&lang=en&cc=us
are you using an HP 57 Tri-color cartridge? HP printers work best with HP cartridges and often have problems with refilled cartridges. the grinding noise you're hearing makes me wonder if the cartridge isn't seated all the way in its little carridge (the plastic part that holds the cartridge). have you had a chance to slip teh cartridge back out and try gently slipping it back in again?
here's another link to try for info for this model of printer (HP's support site), with specifics about your error message about half way down the page:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu05206&dlc=en&product=79488
hope this helps!
-JW50
Nov 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
Psc 2110 carriage jam
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Nov 02, 2008 | HP PSC 2110 Color Printer
Printer issue
this printer is having mechanical problem,it will cost you something high & in this range u can go for new printer.
May 18, 2008 | HP PSC 2110 Color Printer
HP 2110 ALL IN ONE PRINTER
Take a look at www.fixyourownprinter.com for that model But yes time for the next one I guess
Jun 12, 2007 | HP PSC 2110 All-In-One InkJet Printer
when ever i get that message it's when i use a "Non-HP" replacement cartridge...try using a HP catridge, or most likely, the printer has reached the end of it's usefull life!
you can try a "full reset" of the printer by..
-unplug it and let sit for a little while,
-BEFORE plugging it back in, press and hold both the enter and cancel buttons,
-plug the power cord in, and wait to release the buttons until the display on the printer tells you to,
-in many cases, this corrects some problems (especially that awfull grinding/ratcheting noise).
after many years of faithful service, i think mine is officially dead though...even the full resxet doesnt help.
Oct 26, 2006 | HP PSC 2110 Color Printer
46 people viewed this question
jasbo
jasbo
