Question about HTC TYTN GSM Phone
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEARED ON MY SCREEN???
I took the battery out to take out my SIM card but changed my mind, so I put the battery back in and turned the phone back on...a red, green, blue and white horizontal color bars appeared in that order. In the red bar it says: HERM200 under that IPL-1.04 (in white) a space down in the red bar: HERM200 under that SPL-2.03 (in yellow) and in the white bar it just says: Serial. What happend to my phone? I tried to reset it and it still appeared? HELP!!
Hey, i had the same problem and i fixed it. i took the battery out and saw the 4 golden tabs behind the battery. there was two tabs that u could pull out. i lightly pulled them out a little bit. the problem was that the tabs wouldnt hit the battery to charge it. thats why it put the tri colored screen on the front. also my charger fit into the charging hole in the phone, but it had to be moved around to much that it did not fit exactly. I have been rough with the charger so it moved the inside of my phone around. i put the charger in the phone and moved it around gently around untill the light lit up on the front at the top by the word at&t. after it was completly charged, i turned it on and it worked perfectly. i hope this helps in whoever may have this problem because i know it sucks!
Thanks
Posted on Oct 12, 2008
T mobile touch pro 2 doesn't power on.
Take the battery completely out of it and let it sit for about 5 minutes. Then install the battery and see if it will turn on normally.
Don
Apr 06, 2012 | HTC Touch Dual Slider Smartphone
I took to batt out to change a sim card. when i
Check that the SIM card is properly seated and locked down. Also clean the contacts of the SIM and the unit with 99% isoprophyl alcohol and carefully re-assemble.
Sep 15, 2009 | Google Android
I cant go beyond the red green blue white screem
Everytime I turn on my phone its like that.
Nothing's wrong with your phone dear.
If you think Im not sure well I have the same phone and I've had it for a year. So Im sure nothings wrong. As long as its operating fine its ok. Believe me.
Just a little check...
Can you still use the camara?
Can you beam a photo to another phone using bluetooth? If yes, than NOTHING is wrong.
If you have anymore questions I'll be glad to help. Just comment back and I'll try to answer you ASAP.
Good Luck!
Aug 07, 2009 | HTC TYTN GSM Phone
Treo 700 P red, white, blue, green checkered screen
Finally found this solution! It is a connection issue at the bottom of the phone where you would plug in the cable to hotsync your phone.
Put in your hotsync cable and wiggle it around really good and it will fix the issue. Do this with the battery out and then pop it in until you have fixed the issue. Took me a few tries as I was worried about how hard to do it, but no problem!
Jul 28, 2009 | Palm Treo 700p Smartphone
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
Partial bootup
it seems to be a defective card since one of my old graphics cards was defective and had the same problem. Also, try reinstalling the graphics drivers.
Oct 09, 2008 | ATI RADEON X1650 Graphic Card
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEAR ON THE SCREEN...
Remove battery , let sit for 2 miniutes . Re install battery , in proper position , hold on button for a few seconds and this should work ...
Jun 11, 2017 | HTC TYTN GSM Phone
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
White screen on my phone sony w550i
Hi this is a almost normal anomaly with sony ericssons - they get the "white screen of death" on a regular basis - on my w550 back in the day - exactly the same thing happened - after reflashing a few times it was back to normal - we are sony ericsson experts if you need it done
http://horizonwirelessonline.com
Jan 22, 2008 | Sony Ericsson W550i Cellular Phone
HTC TYTN GSM Phone Logo
527 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
