Kenmore top loading is very slow to drain. i have to keep running it thru the drain cycle
    Genius:
  • 1,028 Answers
Lean washer back remove pump clips and hose clamps ckd for possible obstruction..also if the drain hose is rubber instad of plastic ck it for kinks or bends better yet replace it with proper plastic hose
Posted on Aug 09, 2008
Slow leak under unit cannot find problem. what specific should i look for?
It is most likely a hose connection from the pump to drain. What you could do is fill up the washer with cold water and color the water with food coloring let the washer rn thru a cycle. on its completion of the wash cycle and after it drains do not let it fill back up. Turn the water supply taps off and til the washer over on its front. With a tissue,(white), find the spot arond the connections where the color has dripped from. Repair that conection and with the washer back uprite run thru a complete cycle to test for leaks as well to purge the color out of the system. You either must do the later or run like h--l if the wife gets that color on her clothes. lol
Sep 28, 2010 | Kenmore 23822 Top Load Washer
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a kenmore elite top load washing machine. It keeps giving a code of ld. Ceral number is SM 9711024
Hello, LD stands for long drain.
If all the water isn't out of the unit within a certain time, the ld will flash.
Could be 2 things.
1) There's lint stuck in the pump preventing the water to drain properly or
2) You're using too much soap causing lots of suds also preventing the pump from draining properly. If this is the case, what you need to do is run the washer on full load with no detergent and clothes. Let it go thru the cycle and get rid of eccess suds. This is most likely your problem.
Best of luck :)
Aug 19, 2009 | Washing Machines
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
I have the Kenmore elite calypso washer and it stops and displays LD. What does this maean and how do i fix it? Thanks!
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 24, 2009 | Kenmore 2295x Top Load Washer
Washer will not spin properly on a Kenmore 110 23812100
your pump is partially clogged or your drain hose is kinked
Dec 09, 2008 | Kenmore 23822 Top Load Washer
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
