Question about Karcher K DS 5500 Vacuum
5500 model low suction is it possible that filters are the problem the filter on top of water tank is dirty and exhaust filter is also dirty
  • bag6 Sep 12, 2008
    Low suction, my filters are good.
  • 14 Answers
Change the filters & ensure that the water container is properly seated in the machine.If the water tank is not sealing correctly the machine will not genrate any suction.
Posted on Mar 06, 2009
Why is the recovery tank on Hoover f6212-900 not filling up?
Hello! There are a few things that can cause the cleaner to lose suction. Please try these quick steps.
1. Remove the dirty water tank.
2. Clear the filter screen of any dirt or debris.
3. Turn the cleaner on, check your motor suction by the filter screen.
4.. Replace the dirty water tank making sure it is flush to the cleaner on all sides.
5. Lift up on top of nozzle and slide off cleaner.
6. Wipe debris off nozzle and front of cleaner with a damp cloth.
7. Replace dirty water tank.
If you felt suction by the filter screen your suction should now be restored. Hope this was helpful!
Jul 21, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
Ralph, Can you walk me through taking mine apart and cleaning it? My 11mo son tipped mine over after vacuuming one day while it was still full of dirty water. I set it out to dry for 24hrs and then tried...
If it's a single speed model it has two filters which should be replaced Avery couple years. There is an exhaust filter on the back which you must un-clip or un-screw to remove the cover holding the filter in place. This is a washable filter which should be washed after each use and replaced every couple years depending on use. Single speed models also have a cooling filter which is in the motor compartment and should be replaced every couple years by a qualified technician
Oct 02, 2013 | Rainbow E series Canister Wet/Dry Vacuum
My Hoover steam vac spin scrub will not suction up the cleaning solution . Why is there no suction?
p{margin-top:0px; margin-bottom:0px;} Hello,
Thank you for your recent e-mail. I am sorry to read about the problem that you are having with your cleaner.
Please make sure your recovery tank and lid are installed correctly and forming proper seals. Make sure that your filter is clean of any debris. Clean the screen in the tank lid. Make sure your nozzle and squeegee (if on your model) are free of dirt/lint/hair and attached in their holsters correctly. Make sure you do not have any clogs in the hose.
To restore suction, please try the following:
*Remove dirty water tank and clean filters- main reason for low suction is dirty filter
*Verify the dirty water tank cap is not missing.
*Verify dirty water tank lid is inserted completely into unit.
*When cleaning, the yellow float inside of dirty water tank should be free moving.
• First remove your clean water tank and unplug the machine
• Remove the dirty water tank lid and push the front panel piece (square plastic sliding piece in the front of tank) down to make sure it is inserted all the way.
• When reattaching the lid, hook the tabs on the front of the lid to the tank first, then click shut in the back. Pull up on the lid firmly, it should not lift at all. If it does, try reattaching as a seal needs to be formed for suction.
• Test to see if suction has been regained.
If these suggestions do not solve your issue please call a service center.
Your cleaner has at least a 6 month warranty for manufacturing defects. This warranty begins from the date of purchase, with the original sales receipt. If you do not have the original sales receipt, the warranty may be verified at the warranty repair center by MFG or serial number.
Please visit www.Hoover.com and click on service center locator for a list of authorized dealers in your area for service and warranty assistance.
Sincerely,
Hoover Customer Service 62
1-800-944-9200
Mon - Fri 8am to 7pm EST
**Please do not reply to this email address. This is for outgoing messages only.**
servlet.imageserver?oid=00da0000000yf5q&esid=018g0000005bxv6
ref:_00DA0Yf5Q._500G0AodT5:ref
Aug 08, 2012 | Hoover SteamVac F5914-900 SpinScrub...
My SteamVac SpinScrub works fine then all of a sudden, the noise level of the vac seems higher and does not **** up water. I turn off vac then turn it back on, works good for awhile, then noisy, higher...
It sounds as if the ball in the tank in shutting down the suction prematurely. Be sure there is a gap of about 3/4 inch between the top of the filter inside the tank, and the lid of the dirty water tank. Without this gap, suction will pull the ball up too soon.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
It wont **** the water
take your dirty water tank off your machine. look for a lint filter located on the body of your machine. if ther is any obstruction on this part it will eliminate any suction. the lint filter is located behind the dirty water tank where the water comes out of the machine.
Aug 20, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Will not **** up dirty water
If this is a Hoover Steamvac, check to see if there is a foam filter on the indise of the recovery tank lid. If there is, there needs to be at least a 1/4 in. gap from the top. Is the recovery tank lid locked down all of the way around? On some models there is a duct that inserts in front of the recovery tank, if not there, you have no suction.
May 19, 2008 | Hoover Vacuums
I HAVE A BISSEL SPOT BOT THAT WON'T **** UP THE DIRTY WATER.I TRIED TO TAKE IT APART TO CLEAN IT, BUT DIDN'T GET VERY FAR. ANY SUGWSTION? THANKS, ...
No Suction
Possible Causes Remedies
Tank is full. Empty tank.
Dirty/Collection tank latch is not down. Push latch down, securely
into place.
Black Valve on the Dirty/Collection Tank is missing. Replace Black Valve into Dirty/ Collection tank.
Usually there is a seal out of place, or a filter is clogged, so you lose suction.
Apr 30, 2008 | Vacuums
Solution not being picked up
Is the filter inside the lid of the tank clean? Is there a gasket between the tank and the top of the clear window. If you take the tank off, and run the machine, there should be suction coming from the square shaft, but if there is a clogged filter, or that gasket is missing, it will loose that suction and won't extract the water.
Nov 26, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
The automatic shut off
Check the filter on the inside of the lid for the dirty water tank. It needs to have a 1/4 in. gap from the top of the lid to the top of the filter.
Oct 13, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Karcher K DS 5500 Vacuum Logo
556 people viewed this question
Top Karcher Vacuums Experts
kbright1
Level 1 Expert
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
