Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon PC 1080 F ADF Problem
When I fax, about one and a half pages will go through the Automatic Document Feeder and then the fax stops and no other pages will feed.
Is there something I can do to make this run smoothly. It suddenly happened and was not a gradual situation.
Thank you for any help you can give me.
Call canon for instructions on how to clean feed roller and ADF path; otherwise probably need new seperator pad and possibly paper feed roller
Posted on Dec 19, 2008
I'm trying to fax with my Canon MX310, do the fax papers I'm sending go up or down? thanks
Documents need to be face down if you put them on the glass or face up if you have an ADF (automatic document feeder) for single sided pages.
When you put the document on the glass line up the upper right corner of the page (as looking at the back of the paper) with the marker at the left back corner of the glass. If you are using the ADF, put the paper in such that the bottom of the page goes into the ADF first.
I hope this helps.
Sep 16, 2011 | Canon PIXMA MX310 All-In-One Printer
Cannot print screen shows ADF.what does this mean?
Hi!
ADF stands for Automatic Document Feeder and it means the device mounted on top of your pixma that allows multiple pages to be scanned/copied/faxed one at a time automatically.
Now why does it not print? The machine "believes" some document is inserted in the ADF in order to be scanned/copied/faxed, and wants that operation to be completed before it accept any print job. Please remove, if present, any paper from the ADF. Maybe its only some small piece of broken paper or even dust on the sensor in the ADF.
Aug 08, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
  1. Press <Stop/Reset>.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
I need help faxing. It is saying incomplete transmission followed by ADF?
You probably should include some extra information here. (do you get a dial tone? Faxing from the glass or the Auto Document Feeder? Long distance? Do you have another phone that you could "listen in" to the fax call from?)
I can tell you that ADF stands for Automatic Document Feeder though.
Jun 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Looking for a canon f50 multipass reference manual. Reason: trying to use flatbed scanner to scan - not the automatic document feeder. automatic document feeder works. The article I wish to scan does not...
To scan from the platen glass:
1. Click the "Setting" icon on the multipass toolbar
2. Select "Toolbar Settings" tab
3.Under "Image Source", click the "Scan From" drop-down menu and select "Platen"
Mar 02, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
247 people viewed this question
old marine
old marine
