Gateway 330s when i try boot i get 3 beeps -put the memory in another pc its ok .. i checked all cable inside they seem ok .
  • Sir Hyperbol Nov 29, 2008
    Well the computer turns on, the green light comes on, the fan goes, the motherboard green light comes on, the cd drive works, after a pause the fan goes fairly quiet (it is noisy to start with normally) then a scrambled bleep like a loud 56k modem sound happens 3x with a slight pause between.  Then 3 beeps at the same speed and pitch.  Sometimes the scrambled modem sound happens first, then the 3 bleeps, other times just the 3 bleeps.  Removing the ram and cd drive and floppy drive power cables make no difference.
    I am fairly sure the memory is ok (untested), but with no ram in at all the exact same sequence of bleeps occurs.
    Other points, the keyboard lights up (capslock etc), and there is no video signal at all, the monitor stays in standby mode.  I have disconnected everything except the power supply to the computer (externally not inside the case), and it is the same.
    The question I suppose is what exactly does the 56k modem dial up type noise mean before the 3 bleeps if anything (and note there is no 56k modem that's the nearest thing I can compare the sound to).
    And secondly would you automatically get 3 bleeps + no video signal with no RAM in the computer at all?
Have you checked the beep codes on the gateway website?
did they tell you the memory was bad?
If you put another memory stick in does it still beep?
Just a few ideas.
Posted on Aug 08, 2008
Computer will not boot up
3 beeps points to ram problem, try removing the memory and putting it back, sometimes it'S just a bad contact... else, try new memory.
May 22, 2014 | Gateway DX4870 Desktop DX4870-UM20P
Gateway PC GT5028 cpu fan comes on and stays on, but the computer does not boot, the screen is black and there are no beeps. I have replaced the power supply and the video card, but no joy. I also...
Just try putting your memory stick 1 at time, then on the pc, check each memory likewise mentioned. If this dosn;t work, trying taking out all the hardware attched to the motherboard, including hard drive, cd-rom. Now just try with to on your motherboard with basic hardware, video card, single ram. Hope you will find the problem, isf it is mainboard...best of luck.
Sep 17, 2011 | Computers & Internet
All i get is a beeping My gt5220 will not boot...help
Does there seem to be a pattern to the beeps? (long beep, pause, long beep or 3 beeps and a pause) The codes will depend on the motherboard and BIOS manufacturer. One of the Gateway code lists: http://support.gateway.com/s/MOTHERBD/Intel2/WMEBLKD925XBCLK/WMEBLKD925XBCLKfaq17.shtml .
One beep is a CPU error. Three beeps is a memory error - you can remove and reseat the memory one stick at a time to find a bad stick causing them all to fail. Eight beeps is a video error.
I hope this helps.
Aug 29, 2010 | Gateway GT5220 PC Desktop
GT5058 memory and boot issues
If you are tired then you just simply format your system after taking back up of your important data
Dont worry about it it is a small problem and I know that you can fix it
thanks
have a great day
May 02, 2010 | Gateway GT5058 Desktop PC
I get 3 beeps and no video on my gateway desktop
The beeps usually meen that the memory is either incorrect or not inserted correctly. Try removing the new memory and go back to the original configuration. Though not recommended, putting the memory in while still plugged up should not be the problem.
Sep 01, 2009 | Computers & Internet
Help with 3 beeps-fan running- cleaned memory - no boot
3 beeps is a memory problem. That's the BIOS telling you something isn't right. The operating system doesn't matter, this is before the OS. Try like the last reply stated, insert 1 memory stick at a time, and boot the machine trying to eliminate the bad memory stick. It could be an insertion problem also, so re-seat the memory. This should do the trick.
Hope this helps!
Jun 20, 2009 | Gateway GT5408 PC Desktop
Getting error beeps-1-8-2-1 and I need diag. chart info
Try removing all connections to M/board except for Video card and memory and boot if computer boots with no beeps try fitting others one at a time until beeps happen that is faulty unit
if will not boot without beeps try different memory
Also check cables into hard drive are fitted correctly
stripe goes nearest 4 pin power plug on H/D CD DVD and floppy
Aug 24, 2008 | Gigabyte GA-7ZM Motherboard
PC will not reboot.
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | Gateway GX7022E (RBGX7022E) PC Desktop
Acer ast180
The beeps that you are hearing are messages created by the POST (Power On Self Test) to indicate that something is wrong. If you know your motherboard type it is possible to find the documentation explaining what 3 beeps mean.
Because we don't know the motherboard type (At least for now) let's use the common sense.  Did you verify that the power supply is properly connected to the drive?  Can you confirm that removing the second Hard drive it boot again ok? In some type of BIOS 3 beeps means memory problem. By accident did you touch the memory? Are all the ribbon cables well plugged in?
Oct 20, 2007 | Acer Aspire™ T180 PC Desktop
Boot beeps
re check all inserted pci cards and all memory, reseat if necassary. Have you recently upgraded anything, if so remove. Continuos beeps can also indicate processor power failure.
Mar 19, 2007 | Soltek SL-65KV2-T Motherboard
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
