Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp 6110 Remove and check cartridge
I have tried everything - replaced the cartridges, cleaned with distilled water - any other ideas or is the life of the printer over?
  • 1 more comment
  • JillRK Aug 09, 2008
    How do I perform the Cleaning Cycle?
    One of the white ribbons next to the cartridge carrier looks like it might be slightly frayed - could that be the cause and is that something easy to replace?
    Thanks - I will try that.
    Novelist:
  • 158 Answers
Try using a pencil eraser to clean the copper contacts on the cartridges. Also, try running a CLEANING CYCLE for all colors. The CLEANING CYCLE can be initiated from your PC.
Posted on Aug 09, 2008
  • Phil Oellrich Aug 09, 2008
    The white ribbon is the data line for the print assembly. If it is dqmqged, it is probably the cause of your problem. Go to www.hp.com and left click on SUPPORT AND TROUBLESHOOTING. Tell Hp about the frayed cable, and they will advise you if you can replace it yourself, and how you can obtain a new one..Depending on several factors, the part may be under warranty, or may be part of a recall program if others are having the same problem as you.Be sure to ask HP.
My HP Photosmart 2710 All In One Printer has the following error: "Remove and check cartridge on right". I have removed cartridge, restarted the printer and my computer. Nothing seems to get...
Is this a new HP cartridge and the correct one for your printer? If it is a refilled cartridge, try replacing with a brand new HP cartridge.
Next try cleaning the contacts on the cartridge and the cartridge carrier. (While you are at it, make sure that there is no left over tape on the cartridge or other issues blocking the cartridge) To clean have distilled water and lint free clothes available. Bottled water and coffee filters will work. Tap water is not a good choice for this. With the printer on, open the printer cover and wait for the unit to stop moving the carriage. Remove the right cartridge and then unplug the printer. Then dampen your first cloth (wring out any excess water with your fingers), wipe the electrical contacts until no excess ink or any dirt remains. Do not touch the ink nozzles.
With another damp cloth, wipe the contacts in the cartridge carrier.
Either let everything sit for 10 minutes or dry with another lint free cloth. Reinsert the cartridge, making sure that the cartridge is fully seated in the carrier. Then plug in the printer. Finally close the printer cover.
Check if your error persists. If it does, try cleaning the contacts again. If the error repeats again, try a new cartridge if you haven't yet done this step. If a new cartridge fails to solve the problem, check if the cartridge is under warranty. If it is, contact HP.
One option is to try printing with the right hand cartridge removed. This will provide grey-scale documents if black is left in. If you only have the color cartridge in place, your pictures may look odd.
I hope this helps.
May 10, 2011 | HP Photosmart 2710 All-In-One InkJet...
My hp 6110 has a flashing exclamation mark and says "Remove and check cartridge". I have removed and replaced both cartridges several times but the light stays on and the message still appears. HELP!
Hi
remove cartridges
get a peper towel
and clean metal contacts of cartridges
and the metal contact of cartridge carrier
if the error insist
you need to replace with new ones
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Left ink cartridge incorrect. It is the right ink
A trick which may work is cleaning the contacts on both the cartridge and the printer.
Make sure you've switched it off first, I'd try gently buffing with a soft dry cloth first.
HP reccommend using distilled water and cotton buds, but not alcohol based cleaning fluids.
Allow the water to evaporate before replacing cartridge and switching on.
May 11, 2010 | Dell 946 All-In-One InkJet Printer
HP 6940 color cartridge light will not stop blinking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
I might have an idea why this is happening....The print cartridges might need cleaning...
Follow the steps below to do this....
Step one: Remove the black, photo print cartridge, or the gray photo print cartridge
NOTE:
The black, photo print cartridge, or the gray photo print cartridge is in the right side of the carriage. -Lower the cover of the product.
-If the print cartridge status light flashes, proceed to Step two: Replace the print cartridge.
If the print cartridge status light is off, proceed to Step three: Manually clean the print cartridge.
Step two: Replace the black, photo print cartridge, or the gray photo print cartridge and remove the tri-color print cartridge
- Remove plastic tape from new ink carttridge CAUTION:
Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper electrical contacts.
NOTE:
The tri-color print cartridge is in the left side of the carriage.
-Lower the cover of the product. -If the print cartridge status light stops flashing, proceed to Step three: Manually clean the print cartridge.
If the print cartridge status light still flashes, replace the tri-color print cartridge. If the issue continues, service the product.
1. Gather the following items to clean the print cartridge and carriage:
o Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
o Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
o Sheets of paper or a paper towel to rest the cartridges on during cleaning.
2. Open the product cover, and wait until the carriage stops moving.
3. Remove the print cartridge, and place it on a piece of paper with the nozzle plate facing up.
NOTE:
Clean the contacts quickly so that the print cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
4. Unplug the product.
5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
6. Clean the print cartridge contacts. Do not touch the nozzles.
7. Clean the contacts in the carriage, inside the product.8. Either let the print cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
9. Reinstall the print cartridge.
10. Plug the product back in.
11. Close the product cover.
Good Luck!
If there is anything more I can do for you please let me know if not and the problem is solved please rate it, Thanks, JCE
Apr 14, 2009 | HP Deskjet 6940 InkJet Printer
Remove & check cartridge message
What you could try do is to remove both cartridges, close cartridges cover
Unplug printer for awhile, at least 30 minutes
Plug in printer and wait until printer stop
Reinstall both cartridges
This is to let the printer reset and do a new installation of ink cartridges
Feb 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Remove and check color cartridge
the internal circuit of the printer which connects the colour cartridge is gone faulty so this error.that internal circuit needs replaCEMENT.thanks
Dec 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 6110 all-in-one won't print despite new cartridges
make sure that the housing that holds the cartridges are clean at the contacts, this can be done with the machine turned off and unplugged, clean the contacts with warm water and a damp cotton bud not wet and then dry it with a paper towel.
make sure everything is dry before turning the printer back on, if this doesnt work then it needs a service.
Nov 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP officejet 6110 all in one
Probably one of two causes:
1)Cartidge is Faulty/Out of Date/Not original.
2)Printer is Faulty.
Most HP cartridges have a specific life, no matter if you use it or not. You should check the cartridge life - its printed on the cartridge itself. If its in date and broken you can get a free replacement from HP. Try a new cartridge first.
If you are still getting an error message after changing the cartridge and your printer is no longer in warranty, its normally cheaper to throw it away than get it fixed. If its in warranty, call HP. They normally replace very quickly.
Sep 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Remove & Check Cartridge message
Hi Scallag,
Please check with the ink cartridge numbers given below.
HP Officejet 6100 series All-in-One model Black cartridge Color cartridge Photo cartridge HP Officejet 6110, HP Officejet 6110xi, HP Officejet 6110v HP 56 HP 57 HP 58
Click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01299067&cc=us&lc=en&dlc=en&product=79477
Here is the other web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01300415&cc=us&lc=en&dlc=en&product=79477
Have a great day!
Mar 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
206 people viewed this question
Seeker5211
Seeker5211
