Gorenje with error code 7 what is the problem ?????
Error 7 and water inside drum. Sock stucked under tank blocking water to go out. Turn off watter and power, drain washing mashine manually through filter, remove back and bottom cover, remove 2 tube clips from black flexibile thick tube and remove any subject except ball in elbow. You need just screwdriver, muscles and some time. Good luck.
Posted on Mar 15, 2013
2 Suggested Answers
SOURCE: error code 4 Gorenje 63160
First of all:
go to this link and print out the documents. This is a service manual for self testing the washer. http://dc342.4shared.com/doc/FM0C3Sem/preview.html (SPAM FREE)
Run the self test
If the machine self test give you these errors:
Sensor NO
Washing Error
There is probably a problem with the washing sensor wire connection in the bottom of the machine.
Do this:
- Unplug the power
- Turn the machine 180 degrees so you get access to the rear service lid.
- Unscrew the screws on the lid.
- In the left hand bottom in the rear you wil see the water pump. This has two connectors with two blue wires on each connection. One is connected to the bottom of a white connection box on the bottom of the water pump. The other one goes over the top to a plastic joint connector. In my case this one was cut of for some reason.
- Uncut the strip that holds the blue wires in place on the water hose. This will make it easier to work with.
- Unplug the two blue connector plugs. Mark somehow or make sure you remember where both of them go.
-Open the connector on top where the blue wires goes inside the connector plug.
- Check if the cables are intact and in place in the plug. If you are unsure, take out the wires cut of 10mm and strip about 6mm making the copper appear.
- Mount the wires in the holding clamps.
- Connect wires back
- Run self test again
- If ok. Connect the back service lid again.
Posted on Nov 01, 2011
I have an E5 messaage on my new Gorenje IT65KR what does this mean?
All codes can be found here: http://www.texient.com/2011/10/induction-cooker-not-working-error-code.html
Dec 04, 2014 | Office Equipment & Supplies
How do reset for washing machine
I do not see a way to do a reset on this unit. This is the manual and shows what things you can try. Manuals Gorenje UK
Sep 30, 2014 | Gorenje W7543LR Red 600 mm Washer Front...
Gorenje dishwasher e1 error
I know that this is an old topic but I have exactly the same problem. Did you manage to fix it?
Jan 26, 2013 | Gorenje GV 62110 23 in. Built-in...
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
Gorenje KE267MLA Fridge too warm
higher the number, colder the fridge ie 7 is the coldest setting
switch with red dot is for summer/winter operation. only necessary to switch it on if the appliance is in a cold location
Sep 30, 2008 | Gorenje Refrigerators
Washing Machines Logo
7,433 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
