Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis washer
The washer keeps beeping.
  • mjcrober Aug 18, 2008
    Mine won't stop beeping either. It is still washing fine but that beep is driving us crazy. It just keeps going back and forth between the off and on.
  • unbeldi Feb 21, 2009
    My Oasis HE also beeps constantly while washing, and will even start beeping in the middle of the night when it is off.  I have to unplug it every time I am done using it.  This is absolutely the crummiest washer I have ever owned, and I will never buy a Kenmore again.  Five minutes after the warranty ran out, the locking mechanism broke and cost hundreds to repair.  This should be a recall item.  I fear it could even start a fire if I were to leave it plugged in.  I will not invest one more cent on repairs on this piece of junk.   I tried unplugging any other items on the same circuit as suggested by the other owner, but that doesn't work for me.
  • 3 Answers
The user interface panel seems to be susceptible to interference off the power line.  in my case, i had incessant beeping during the wash and sometimes even random start ups but when i removed an air wick air freshener from the same power line, the washer immediately worked fine again.
Posted on Feb 18, 2009
  • 5,911 Answers
This is a common problem with the Oasis. The problem is the User Interface Control board behind the control panel. There's a relay on the board that shorts out and causes the washer to randomly (and constantly) beep. This can also occur with the washer turned off. Since the circuit board is not serviceable it is recommended that you replace the control board. Searspartsdirect.com carries replacement parts for your washer. Just type in the model number and search under the console heading for the user interface board. If you are usure which part, I'm talking about, please post back with your model number and I can assist you. I hope this helps.
Posted on Aug 19, 2008
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Posted on Sep 25, 2010
Macmarkus
  • 2605 Answers
SOURCE: I keep getting the OL message on my Kenmore Oasis
Hello, welcome to FixYa.
I'm pretty sure I know what you're referring to and contrary to what has been posted by another FixYa memeber, it likely is not the motor assembly...more often it is just an item stuck under the basket/drive hub as most with REAL experience would know.
In fact I can explain what needs to be done to gain access and repair though it is pretty involved (via removing the tub...it's pretty easy once you see how...much easier with the manual and some guidance).
As I alluded to, it is most likely the drive/spin basket hub under the inner basket (spin basket) and it is being jammed by a sock, undergarment or the like, but you'll need to remove the complete outer tub assembly unfortunately.
This almost always manifest's in the "oL" error code (possibly even error "UL" & "F51") and prevents proper wash or spin...though it usually will certainly fill and drain O.K...unless the error appear's many times it may simply go into a shut down/no action (F1) mode.
I can provide a follow up post on how to do this, including pictures and step by step guidance if you think you are capable, or I alternatively can provide you a service manual if you post an email address.
I'll watch for your reply. Thank's for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Oct 18, 2011
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis no error code keeps beeping low -loud
If its the main board that you are having an issue with, honestly i will suggest to get a new one instead, might cost you as much as buying a new one if you are going to have it repaired.
May 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Need to know what 50 means --washer keeps beeping after tub fills
Please see the following Whirlpool Service Manual for their Cabrio Washer (Basically the same as the Kenmore Oasis)
50 points to an obstruction keeping the basket drum from turning freely.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Nov 08, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis Washing Machine
the user interface board is bad.
Jan 08, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis electric dryer beeps and displays code F45
We had this error on our machine for about a year before we finally got sick and tired of it. Our dryer was purchased in 2006.
Here is the solution: the code means there is an error on the thermistor. Our thermistor was loose, as were other electrical wires. My husband tightened up all the connections and the thermistor, and we have never had this error again.
However, we will never buy these machines again either, because we have had numerous other errors on the washer and dryer.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Beeping
stuck key or bad control
Nov 09, 2008 | Kenmore Oasis HE 27082 Top Load Washer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
140 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
