Boot up reformat hard drive etc
Ok so when i boot up with my millenium edition cd from the cd drive it eventually tells me that there are no files found on d:\drive (only 1 hard drive c:)
usually this cd will make a virtual drive d: and i can find setup.exe and can then install millenium and then windows xp. I suspect a hardware problem but knowing that packard bell are that little bit different thought i would ask here first. any help most appreciated,
sub
    Genius:
  • 2,028 Answers
This could be an issue with the hard drive. Try formatting the hard drive, if the drive won't format, then it's bad. If it will, then you may have to create the D: drive partition. If you're running both operating systems out of one drive then you will not have to create the separate partition, but you will need to run the set up on both discs. If it will not allow you to create the partition or run the set up, then the disc may be corrupt or damaged. Let me know how this turns out.
Posted on Aug 08, 2008
External Hard Drive won't format. Should I wipe it and then, try again?
try to format it through the disk management program in the control panel
Feb 07, 2013 | Western Digital Computers & Internet
My operating system was damaged by virus,i need ro reformat my computer..how can i reformat my competer?
Install the XP discs and restart the machine. It should boot from the discs. Then follow the onscreen instructions. You will want to reformat your main drive. (C:)
Apr 04, 2011 | Microsoft Windows XP Home Edition Service...
I have a HP Pavilion Elite m 9357c that willnot boot up. The screen goes black and says Disk Boot Failure,Insert system Disk and press enter
If it happens that you are prompted by the following error message "DISK BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER", "No system disk", it means that the computer did not find the operating system to start (boot).
Causes:
A diskette or CD has remained in the drive
Check out if any diskettes, CD-ROM or DVD-ROM are present in respective drives, remove them and restart your computer
The boot sequence is incorrect BIOS
Enter the BIOS setup of your computer and edit the boot (boot sequence) so that the computer starts primarily on drive C:
A new hard drive was installed
In the case that a new hard drive has been installed, this message is quite normal.
Just insert the correct CD to install the system (usually Windows), then restart, while making sure the CD-ROM is first in the defined in the BIOS setup as first boot sequence.
The hard drive is unplugged
Open the system unit and check that power cable of the hard drive is properly connected.
Corrupted system files
It may happens that some system files needed to boot the computer have been deleted /damaged or that the boot sector of the disc is damaged.
To determine this, start the computer with a system disk or CD-ROM installation of Windows (via the Recovery Console), and once started, type Dir C: to check if the contents of drive C: are accessible. If its ok then the problem comes from missing or damaged files, then you just have to run the command:
fdisk /mbr
sys c:
Note that before any restoration of the boot sector with the command fdisk / mbr, (supposing that there is a virus), it is recommended to use an antivirus running under DOS, such as
f-prot.
http://support.microsoft.com/kb/166454/en-us
http://support.microsoft.com/kb/69013/en-us
Damaged disk
If the hard disk or a partition is damaged:
If it detected in the BIOS setup, there is a chance that it is
not out of service.
If it is, try reinstalling the system through the installation CD, in order to reformat or recover the partition using a utility.
Feb 03, 2011 | HP Media Center m7260n (EG642AA) PC...
I got a hp cd-writer cd12 series multiread cd-r/rw on a really messed up windows millenium edition computer yet it reads as cd-rom only drive i'm tryin to no success and will keep tryin to fix that so i...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
or
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
Dec 26, 2010 | HP CD-Writer Cd4re CD-RW Burner
How to reformat a computer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 19, 2010 | Microsoft Windows XP Professional
System will not boot
If you have special data on the drive(pictures) then use the freezer trick.(I'm not gonna go into details google it) If not, then you should just reformat the hard drive using the CD that the laptop came with. Remember to go into the BIOS and change it to First Boot Selection: CDRom drive. You should be able to delete the old partition and then create a new one, then install windows. If none of this works, contact Acer.
Feb 05, 2010 | Computers & Internet
Cannot reinstall new os seems my hard drive has been block by some kind of protection
If you are install xp to a computer that had vista or has a sata hard drive.The SATA drivers must be loaded during setup.If this is not the case,Please post back with more details.
May 16, 2009 | Acer Aspire M1640 Refurbished Intel...
Reformat
step 1 - First insert the windows xp cd in your cd drive.
step 2 - Then start your computer and keep pressing F12 key on your keyboard.
step 3 - After pressing F12 key,it will show you some options to select from where you want to boot from.
step 4 - Select 'Boot from CD drive/USB cd drive'
step 5 - Now it will try to boot from your bootable windows xp cd which you have inserted in th CD drive.
step 6 - After reading the CD it will prompt you to 'Press any key to boot from CD drive'
step 7 - At this moment press any key.Remeber you will have to press any key while this prompt appears.otherwise it will boot from your Hard disk drive.
step 8 - After pressing any key it will start windows xp setup.
Thanks
Feb 12, 2009 | Dell Microsoft Windows XP Home Edition
Reformatting harddrive
You have said that d:\ has the xp you can still install windows 98 in c:\ doesnt matter but the file system must be fat32 if you install 98 in c:\ you must manually edit boot.ini in c:\ to get acess to xp of the d:\ iwill tell you how to if you are interested
Jan 20, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Hello the hard drive of our laptop needs a full reformat so i can reinstall xp but how do i format it without a working opperating system? thank you
 You can do a full reformat right from the windows xp install disk.  Put the xp disk in the cdrom drive and restart the computer.  Upon restarting a message will come up ( Hit any key to boot from CD )  Hit any key,  the files will load then you will be able to format the hard drive and also load windows XP.
    If for some reason your system doesnt boot from the cd, you might have to go into the Bios and change the boot order from the hard drive or the floppy to the cd so the computer will boot from the CD first. Hope this helps...                                                           Joe > Data Miner <
Oct 31, 2008 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
