Question about Maytag MSD2732GR Side by Side Refrigerator
Ice buildup at bottom of freezer and small puddle.
Ice is building up at the bottom of my freezer and I am getting a small puddle on the floor every couple days. just under the freezer side at the front. Any ideas would be greatly appreciated.
  • 828 Answers
Freezer has a drain in the back under the cooling coil. Melt Ice from drain area with a hair dryer, check drain and clear, under bottom in back behind a removable panel you will find the drain exit from the freezer going into the drain pan. This drain line has a loop for air seal, make sure it is cleared.
Posted on Aug 09, 2008
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
There is one button in the freeze. By pressing this button you can de- freeze it. Water will collect in a container which is at the back of freeze.For more details check out http://mistercold.com/koolit-golf-cooler.html
Posted on Oct 01, 2014
My bottom mounted freezer continues to freeze up and leaks a small puddle on the floor
You have a drain hole behind the rear wall of the freezer compartment. You will need to remove the shelves, screws and clean the hole of ice and gunk. here is a video below.
Leaking Refrigerators Leaking Refrigerators
Appliance 911 Sea Breeze
Aug 02, 2015 | Refrigerators
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
Dec 29, 2013 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
I( find a puddle of water on floor at front left hand corner on freezer side..I took the freezer drawer out and found ice build up under it ,could this cause my problem.. this happened about every 24 hours...
The problem with your refrigertor is that the defrost drain is plugged up. After you get the ice buildup out of the freezer section you will have to locate the drain system. It is in the back of the freezer at the very bottom.It needs to be cleaned out. Hope this at least leads you in the right direction.
May 27, 2011 | Maytag MSD2756G Side by Side Refrigerator
LG LFC21760ST: In freezer area floor, there is ice build-up. Water is leaking from the back wall where two horizontal openings are (near the center). We've turned off the water for the ice maker but this...
If you shut off the water to the ice maker, the only other cause is a plugged drain hole. Somewhere around the bottom of your freezer there will be a small hole that allows moisture to drain out of the freezer and into a catch pan under the refrigerator. If this hole is plugged with ice then the water has no where to drain but out the door of the freezer and puddling on your floor. The water you see dripping is condensation that has built up in the freezer itself.
To fix this problem, you need to dislodge/remove the ice from the bottom of the freezer and the hole. I have had the best luck using warm water with a turkey baster. Another alternative would be an ice pick or any type of utensil that can be safely used to dislodge the ice from the whole and the bottom of the freezer. I prefer the water method because it is the safest. Ideally what you want to do is force warm water in small quantites down the hole. This will melt the ice and reopen the drainage. You then need to remove any ice around the bottom of the freezer using warm water. When done make sure to dry the bottom of the freezer.
May 05, 2011 | Refrigerators
LG Refrigerator model # LRFC25750TT Twice, I've found a small puddle of water in the front right side of the refrigerator (as you face it). This was found approximately 2 weeks apart. I've check the...
Hi
To identify whether your unit is leaking, please check the bellow link to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itleaks
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | LG Refrigerators
Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice Buildup in Bottom of Freezer
Hi: The tube in the back of the freezer is not clogged with ice. It is most likely clogged with mold below the freezer section just above the warm tray where the defrost water evaporates. Also a pea or other piece of debris could have gotten in there. Do your thawing again and pour some clorox water through it and use a pipe cleaner if it's a tough clog. I hope this helps, Jeff
Jun 01, 2009 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Freezer icing over at bottom and leaking onto floor
Hi, You will need to remove the rear panel in the freezer and then remove the ice build up in the drain pan. The drain hole will have ice down in it.Make sure all the ice is gone and then flush the drain hole out with hot water (a basting serenge works great)
This should take care of your water problem.
If I can assist you further, please let me know and please rate me response so that other as well as my self will know how I am doing.
Thanks
Vic
May 22, 2009 | Refrigerators
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Maytag MSD2732GR Side by Side Refrigerator Logo
848 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
