Question about Sony Cell Phones
I droped my phone in the water and it turns on but the screen won't work. what do I do
  • 38 Answers
Well, what you need to do is take out the battery first of all. Second of all, you should try baking the phone in the oven on the lowest setting it has, for like 10 or 20 min and let it dry out. It may work after that. If not, have your phone provider back up your phone numbers, and then get a new phone. AND, if you dont really care, you COULD soak the phone in distilled water to cleanse it of any impurities and then heat it again to dry it out.
Posted on Aug 08, 2008
Droped iphone4 in dishwater now screen wont turn on
There are a couple home remedies to try and counter the effect of liquid in your phone. First would be too place your iPhone in a bowl of rice. The rice absorbs moisture. It may draw enough of the water out to dry out the phone and possible make it work again. The other is rubbing alcohol. Place your phone NEAR, not in, the alcohol. Hope you get it fixed!
Mar 13, 2013 | Apple iPhone Smartphone
My Iphone 4 screen wont work
You would need to get it repaired/replaced either way. You can either get it repaired by a third party place that will repair it for you (not sure how much they would charge) otherwise you could just get it replaced from Apple by paying the out of warranty service fee as it would have liquid damage to it.
Dec 15, 2012 | Apple iPhone Smartphone
I droped my lg virgin rumor touch and The touch screen cracked but when I turn it on it stays black. What could I do?
If you won't see anything on screen,check if the phone is booting or turning on,if it turns on,display is probably the problem.but if doesn't power?software problem is the main cause.and with this,need to replace LCD as well as touch screen that was damage too.
If your mobile has a warranty,you can bring it to the service center for spare parts replacement.If you try to open it and it's under warranty,this will void you warranty and unable to benefit free of service charge.
Jun 15, 2011 | LG RUMOR Cellular Phone
I droped my bb storm 9500 without wife, no water or nothing, at first it worked fine but on ocacciones it turns off, but now i turn it on and the screen is pitch black...can u help me?
Its a hardware problem. In that case, try bringing to to a "Certified" Service Center to examine your phone and solve your problem.
Hope this helps! -jayps
Mar 15, 2011 | Cell Phones
I droped it and the screen wont turn on
Since you said the phone drop from you, it is possible that the screws that attach the screen of your phone is not tight anymore.
I suggest you get a torx6 screw driver, power off the phone, remove the battery and turn the the phone over.
Carefully remove the front cover of your phone that leads you to your phone screen.
Use the torx6 screw driver to tighten all the screws of your screen very well to the panel of of your phone.
Recouple your phone back, put the battery and power on, the screen should display.
But if the screen did not display, it means the flex on your phone is bad and will need to be replaced.,
So change the flex if tightening of the screen did not work, so change the flex on your phone and your phone will display.
Take care.
May 08, 2010 | Sony Ericsson T715 Cell Phone
What does it mean when my phone is saying it needs intial programming. i droped in water but it still turned on and seemed to be be working then it started saying it need intial programming on the screen....
when a phone drops in water it needs to be serviced before use, cause the water has damaged the phone board.
service the phone so that the water in the phone will dry up completely.
Have a nice day.
Mar 15, 2010 | Cell Phones
I droped my phone in water and now the touchpad wont work
Did you tried leaving it about a day under the sunlight? If you did try sending it to a store for someone to fix it.
Jul 21, 2009 | LG CHOCOLATE VX8500 Cellular Phone
I droped my fone in water and its in a screen and all it says is emergency download and im wonder how to exit it i took out my batter and put it bak it but it gose bak to the same screen pls pls help
take the battery out and let it dry for a couple of days should restart, but it has to be dry. if it is dry you should follow any directions it say to reload the phone...hope it helps.....
May 28, 2009 | LG Vu CU920 Cellular Phone
Droped my phone into water while back trying to fix it now and goes to blue screen and says bootloader usb init
if you did not take the battery out as soon as you pulled it out of the water it is probily no good because the circuit board was fried from the electric current that the battery was feeding the phone. but for future ref. if droped in the water remove batt asap and take phone apart and dry with a q tip and put back to gether and let it sit for a bout a day to let all the water get out of the phone and then place the batt back in it and turn it on.
Feb 20, 2009 | Motorola Mobility RAZR V3
"download" problem
u probably have dropped ur phone in water.....................takeout the battery and remove the back cover........let it be off for a day or two then check it out............if still problem exists change the battery........actually some of the components are sensative to water....and this problem(red screen) mostly occurs when its droped in water.
Jul 14, 2008 | Samsung SGH-A707 Cellular Phone
Cell Phones Logo
26 people viewed this question
Top Sony Cell Phones Experts
Kasey Johnson
Mirca Sekosan
Mirca Sekosan
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
