Question about Weather King 12AJA6001AH Air Conditioner
Furnace not blowing hot air
I have fored air furnace, i change the switch middle of the winter but after a month start blowing cold air now is time to take care becasue winter is going to be in couple of months, so please can you tell me what wrong.
Thanks
  • Anonymous Aug 09, 2008
    Thanks for your tips, i already try that and everything is perfect, i don't know whats wrong, do you think any other electrical problem like the switch is not giving signal to blow hot air, please let me know. Thank you and God bless you for your kind help.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Also did you check to see if you added a jumper wire to the thermostat rc--rh ! R-means power to C-(cool)_--- r-power-to rh is( heat)! TYVM!
Posted on Dec 08, 2009
All the fans are working.
    Problem Solver:
  • 7 Answers
Check your flu pipe and make sure there is no obstruction in the entire pipe. Sometimes the exhaust fan for the flu will not come on because the safety will not allow it to and it will also cause the fan to run, but not the burners to engage ignition.
Hope that helps.
God Bless.
Erik
Posted on Aug 08, 2008
Furnace blowing cold air
Turn power off & on again. Watch to see if it cycles...it could be the hot surface igniter if you don't see it turn bright orange. If it goes straight to blowing cold air, then normally it is a limit switch open- mostly manual reset - thermal disc-located around flame rollout.
Dec 20, 2013 | Ruud RGTM10ERBJS 100K BTU 95%...
Ruud furnace troubleshooting
check that elements are intact and getting voltage
Nov 14, 2013 | Heating & Cooling
I have a Coleman/Evcon furnace model #DGU08016UB that has a concern. In my attempt to check my furnace before we need it for the winter; the following condition occurred. Condition: Flashing code of...
jump out pressure switch see if it lights check hose to pressure switch see if they are split or connections are not good ,cut off ends and put back on presure switch.
Sep 21, 2011 | Coleman Heating & Cooling
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
AC/heater vent only blow out hot air
that switch controls a vacuum operated door that lets a/c or heat thru.when accelerating,the vacuum in the engine changes so it sound like a vacuum issue.take apart the center stack and there is a vacuum actuator in there connected to the flap door .i have seen those have issues with the metal tab broken away from the plastic that moves it.is the a/c piping cold under the hood where it goes into the heater a/c assembly?the compressor should be cycling on and off and the pressure tested.
Jul 03, 2009 | 1998 Ford Explorer
No hot air & sometimes no air at all
my 2000 dodge caravan heat sometime working sometime not working
Oct 17, 2008 | 2000 Dodge Caravan
Weather King 12AJA6001AH Air Conditioner Logo
1,264 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
