No picture power light blinks. I just shut it of the other day and now it wont come on.
  • tmacustomcar Aug 12, 2008
    The power light just blinks , no pause. The Model # is TP50G60
    No, it did not work
  • 6,487 Answers
Try first to plug the television to another power outlet and check if the unit will power on , if not this can be a problem with the power adapter or with the power supply of the television that may need a repair or replacement ....
Hope that helps.......
Posted on Aug 12, 2008
TV wont come on
Blinking power light indicates fault. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. These are called blinking codes. To know more about these blinking coded, visit the site. It has details about blinking codes to many brand TVs. Pull up older posts. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. http://electronicshelponline.blogspot.com/
Apr 23, 2013 | Panasonic TH-50PX75U Plasma HDTV
After turning on TV, lamp light blinks but no picture
IF IT SHUTS DOWN TO STANDBY, THEN DIGITAL BAORD IS BAD, IF IT JUST KEEPS CYCLING ON/OFF THEN YOU NEED A POWER SUPPLY, BALLAST AND PROBABLY LAMP
Dec 30, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
My picture shut off. Power lite clicks, blinks,no picture
how many times is the power light blinking as thats a error code. 3 blinks is the most famous which means convergence circuit failure.
Oct 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Replaced lamp worked for a few days and now it wont power up, now when you turn it on the light blinks green and then the yellow lamp light comes on and no sound or picture.
when the set shuts down check to see what the error code is, press the input and menu buttons at the same time, hold them down for 10 seconds, the green light should blink a two digit code, if this is 38 then you have a thermal sensor problem and need to call Mitsubishi for extended warranty repair.
Sep 08, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
Feb 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Th-50pz80u turns off for no reason
you can shove your premium assistance program , i spent 2000.00 already
tv shuts off for no reason...red light blinks 4 times ...stops...blinks 4 times....stops....etc....what can i do before taking it back??
this is a brand new unit....fantastic picture....fix my problem
Dec 13, 2008 | Panasonic TH-50PX50U/P 50 in. HDTV Plasma...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
