Toshiba regza Cannot move tv channels up or down either by remote or using buttons on the tv?
Tried turning the tv on ?
Posted on Aug 08, 2008
I REGZA 32 lcd tv, will not work for me function.when channel and press the button on the tv, it says panel lock.what problem?
read the owner manual, the book that came with the set--it is telling you the panel or front controls for the set (maybe the remote also) are locked to prevent them being used, there will be a method to unlock them in the owner manual
Nov 04, 2012 | Toshiba Regza 32LV67U 32 in. LCD HDTV
My toshiba regza 32av615 lcd tv keeps flicking thought the channels on its own
If the set is going up only or down only it is likely the button for each or one on the set itself is bad.
Channel up or any for example is a micro switch-beneath each actual button. They are "momentary" switches which means only work when pressed---a lot of them fail in this way.
A way to know for sure is have someone remove the keyboard(usually on a small circuit board inside) and locate the offending button--up or down and unsolder that switch---usually two or three pins.
The switches can be tested with a ohm meter set very high--should be no reading unless switch is pressed---
If set works now with the switch eliminated either just use the remote or purchase a replacement board--they usually do not sell individual switches
Let me know what happens or if you have a further question.
Apr 12, 2012 | Toshiba REGZA 32AV615 32 in. LCD TV
My tv keeps changing channels on its own. I have taken the batteries out of the remote and tried using tv only but it still does it. TV is only 3 years old
Will you check the channel button at the side of your television if the button will normaly press on.If not,the problem is in the system of your TV.Ethier the system ic is deffective.Its better to repair the authorized technician.
Jul 11, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
How do I unlock the 'panel lock' of my Toshiba Regza without remote control?
Hello
To unlock the panel lock of Toshiba TV, follow this.
Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu.
Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area
Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
Mar 24, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I cant program any channels on my tv. Toshiba 42'' plasma. Do i need the remote or can i do it directly from the tv?
Which specific model from Toshiba do you have? There are several 42" TVs released with the Regza name. Most of the manuals can be found on the Toshiba support web site. http://www.tacp.toshiba.com/customersupport/
The one that I have allows for the channels to be set from the On-Screen Menu. In the TV mode, press Menu (there is a Menu button on the side of the TV). Navigate with the arrow keys (CH+, CH-, Vol+, Vol-) to the Setup menu and highlight Installation and press Enter (the Menu button is also the Enter key when using the buttons on the TV). Then highlight Channel Program and then Start and press Enter. When the search is done, press Ch+ or Ch- to view a station. To add or delete channels, use the Channel Add/Delete that is one line below Channel Program. Use the enter key to change the check mark status next to a channel. If adding a digital sub-channel not previously found, enter the number manually on the remote using the 100 key to add the dash. If the channel isn't found, an error message will result.
I hope this helps.
Jul 28, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
When i turn my toshiba regza on I cannot access DTV all I get is a black screen. when i press the menu setup button this comes on for about a second then goes off again to a black screen. I can still use...
Try either the "content / menu" button between the volume and programme buttons. Failing that, when the tv has been powered up from the wall socket wait untill you hear a small click from the t.v (usually about 5 or so seconds after it has been switched on) before switching it on from the remote control, have no idea why this works but the dtv has worked for me ever since I powered the tv up like that
Jul 17, 2009 | Toshiba REGZA 47HL167 TV
Toshiba regza
the best thig and easiest way would be to reset everything and start overthose things have so many differnt settings but to start turn it off then on the right side it has a power button, hold that power button down for 5 seconds and its reset.
Dec 13, 2007 | Toshiba REGZA 32WLG66 32 in. Television
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
