Question about Kirby G5 Bagged Upright Vacuum
Kirby G5 Techdrive pedal
I was vacuuming and the Techdrive pedal came off. I went over a small ridge on the floor and the pedal was laying there.
We recently had the vacuum in for cleaning but we have since moved and so there is not way I can take it back there. Do I call them? Did the perhaps not get it back in correctly? Do you have any suggestions?
Thanks
  • clwfew Sep 04, 2008
    The self propel pedal came off and it is very hard to push the vacuum. Can I repair this or does it need to go to the repair shop? Any help is appreciated.
  • Kirby Expert
  • 324 Answers
Kirby N/D pedal is an assembly that can not just come out. So I would say that it is most likely broken. See THIS ITEM and if the part that was left on the floor is just a part of what you see in the picture then it is broken.
It is possible to assemble it back together but usually it falls apart again fairly quick and it is hard to get the angle at which pedal must be reassembled. We usually do not mess with it.
Good Luck
Posted on Oct 30, 2008
How do I replace a kirby g7 drive pedal?
Here is a step by step walk through with pictures on how to replace the neutral / drive pedal on any Kirby Generation vacuum (G3, G4, G5, G6, Ultimate G, Ultimate G Diamond Edition, Sentria and Sentria II)
Kirby Neutral Drive Pedal Replacement Guide
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 04, 2014 | Kirby G6 Bagged Upright Vacuum
Kirby g5 techdrive n/d pedal came off will not stay on
The pedal will need to be replaced. A shift mechanism pressed on the end of the shaft has come off and cannot be re-installed. The drive unit must be removed from the machine, and the pedal assembly and shift cam can then be replaced. This may not be a do-it-yourself repair, as a good deal of disassembly is required.
Feb 04, 2011 | Kirby G5 Bagged Upright Vacuum
The TechDrive Pedal on my Kirby G6 fell out of the back of my vacuum cleaner. I removed the screws from the metal plate one the bottom to try to see if something had come a loose. Can you send me a diagram...
This requires removal of the transmission assembly and replacement of the pedal assembly - it cannot be repaired. The handle and upper motor shell must be remove to access the transmission assemby. There are two screws in front, and two under the plastic switch plate.
Jan 18, 2011 | Kirby G6 Bagged Upright Vacuum
The techdrive of my Kirby Vac fell off why and how do I fix it. I am an electrician.
The pedal assembly must be replaced, as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items.
Jan 05, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 gearbox clicks, why?
most of the time the small fork that comes off of the transmission and connects to the top slide wears out which doesnt allow the transmission to engage properly
Oct 10, 2009 | Kirby G5 Bagged Upright Vacuum
TechDrive power assist fell off
See if THIS helps.
Not sure how far you went disassembling the unit so here are a few more useful articles that you may want to see:
How to connect wires
How to get the transmission installed.
Rocky
May 30, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby g5 vacuum
Either the cogged belt broke, or you will have to pull the transmission and see if something came apart. May have to replace the transmission.
Jun 01, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
247 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
