Question about Philips SPC700NC Webcam
Webcam logitech webcam compatability issues with vista Does not want to show picture only on yahoo works on MSN
    President:
  • 8,637 Answers
Normal 0 What it sounds like is that you have not set up the Video option in your Yahoo Messenger program. If this hasn't been done, it will not broadcast your image.
Normal 0 Here is setup Yahoo Messenger.
Which ever Messenger or Skype you are using has to be setup in order to function. All Messengers and Skype have an Audio & Video setup in them so the camera and microphone work properly with their program.
Bring up Yahoo Messenger and on the top left click on MESSENGER.
Then click on "Messenger Preferences."
Next in Category click on "Calling & Devices."
When that comes up check to make sure that Microphone is set to your audio card.
Next insure that the speakers are set to your audio card.
Then go to "Test Audio "In the Blue print "Open the call setup Assistant" When the window opens follow the instructions. When finished your camera audio should function properly.
Also you need to go to the Video setup and do the same so it will broadcast the pictures.
Hope this helps. Bud.
Posted on Jan 10, 2009
Gateway netbook LT2802u. I want to use the built in camera - webcam - manually. It works on Skype - I can take pictures to post for my profile and it works as a webcam. Also I can find the webcam in device...
Your web cam works with software. Any video chat programs or web programs will allow your camera to function. Like Yahoo, MSN, Google, Skype, ooVoo... So you would need a installed a computer program that would give you more control. Check with the manufacturer to see what they have that would give you this kind of control. logitech.com if it's a logitech CAM. If the software isn't compatible with the version of windows.. Then the CAM would only work with web based programs (Skype, ooVoo, yahoo......)
Apr 07, 2014 | Gateway LT2802U 10.1in Netbook 1.66GHz 1GB...
My webcam does not work on msn
first you need to know that if you used xp ...and upgraded to vista ...you need to find a compatible driver for your web cam too ...if your web cam used to work just fine on vista ...and its just the msn issue ...just reinstall the latest MSN messenger and it should be enough ...also verify the proxy servers on the messenger preferences..and set 'em to fit the kinda conexion you use...
but I suspect a problem with the program settings ...so the easy way is just to install the latest messenger(MSN) available for vista ...and it will be ok
May 17, 2009 | Logitech QuickCam Pro 5000 Webcam
Webcam works on msn but the picture is black and fuzzy
go to Logitech's website...click on your product model and from there you can download the latest drivers. Make sure to note that most device drivers for Vista 64 bit systems are different from 32 bit.
Hope this helps.
May 04, 2009 | Logitech QuickCam Messenger Web Camera
My webcam works on msn messenger but not yahoo messenger. It is a HP webcam. Is there a compatibility issue? Should I change my webcam?
No there is no compatibility issue. But you cannot use cams simultaneously on 2 messenger. Make sure that when you using it in Yahoo messenger than msn is totally shut off. Try this it should help you.
If my advice helps you, than please feel free to rate me.
Thanks
Mar 22, 2009 | Logitech Webcam
My logitech webcam only works for msn only and not for yahoo im
you also need to set it up in your yahoo program
do you know how to do that
each webcam program needs setup seperately
Jan 23, 2009 | Logitech Webcam
Haveing trouble installing logitech quick cam onto my comuptor thats running windows vista
This problem was caused by a compatibility issue between Windows Vista and Logitech QuickCam Messenger.
Logitech QuickCam Messenger was created by Logitech, Inc..
Recommendation
To search for similar devices that are compatible with this version of Windows, visit the Windows Vista Hardware Compatibility List website online.
However, it’s not totally out of hope for owner of Logitech QuickCam Messenger who has upgraded to Windows Vista. The following hack will use Windows XP driver (a common trick to use non Vista compliant device) to install the webcam in Vista:
  1. Download QuickCam 8.4.8 with driver for WinXP.
  2. Install WinRAR if not already installed yet.
  3. Open the setup installer qc848enu.exe and unpack its contents to a folder. Alternatively, right click on qc848enu.exe and select “Extract to qc848enu\” option.
  4. Insert or plug in the Logitech QuickCam Messenger to a USB port if not already done so.
  5. An “Driver Software Installation” icon in systray (notification area) should appear, which will pop up detailed message if click. It should fail, and “Add Hardware Wizard” dialog window will appear. Choose to install the driver manually by instructing the Wizard to locate and look for the web cam driver inside the Drivers folder under the unpacked folder of the qc848enu.exe setup program. You can use browser button to select the folder.
  6. Windows Vista should grab the XP driver and install it properly.
  7. Download the latest version (10.5.1) of Vista compliant QuickCam software from Logitech to install the software on Vista.
  8. Run the setup (qc1051enu) normally. You may need to skip the detection of webcam near the end of installation process.
Voila, you can now use the Logitech webcam to capture images or use it in conjunction with video chat in IM programs such as Windows Live (MSN) Messenger, AIM Messenger, Yahoo! Messenger, Skype or run Logitech VideoCall.
i hope thist post can solve your problem
thank's
cropp
Mar 14, 2008 | Logitech Webcam
Logitech webcam
Are you trying to use more than one application with the cam at one time?
Dec 29, 2007 | Logitech QuickCam Express Web Camera
Philips SPC700NC Webcam Logo
41 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
