1999 Cavalier radiator fan and compressor clutch will not engage on ac circuit.
    Problem Solver:
  • 7 Answers
There may be a low pressure cut-out switch involved here and that usually comes from being low or out of refrigerant or (freon).
This also happened to me when I sucked up a bag against the return air by the passanger floor under the dash. It also burned up my motor for the a/c.
Hope this can help.
God Bless.
Erik
Posted on Aug 08, 2008
6ya staff
SOURCE:
Wha causes the compressor to not run when the fan will?
the starter capicator might be bad its on the side of compressor
Aug 17, 2014 | Refrigerators
Radiator fan relay control circuit 2002 dodge ram
low charge pressure of 134A Coolant will not let the fan or compressor clutch engage.
Apr 01, 2014 | Dodge Ram 1500 Cars & Trucks
No electrical power to AC Compressor. The switch light comes on in car when AC power button is turned on.
  1. Check if air blows with the fan setting turned to high.
  2. Check that the radiator cooling fan engages when the A/C button is pressed.
  3. Locate the compressor.
  4. Turn on the A/C.
  5. Check if the compressor's clutch has been engaged.
  6. If the clutch engages, the fault is elsewhere.
  7. If the clutch does not engage, check for power to the clutch.
These steps might help find the problem.
Sep 16, 2013 | 1997 Ford Escort
Radiator fan always engaged when AC is on
Radiator fan is supposed to blow anytime the A/C is on. Thats how you check to see if a fan is working, cause its supposed to blow anytime the A/C is on , but not neccesarily anytime the engine is running.
Mar 08, 2013 | GMC Envoy Cars & Trucks
A/c compreesr cluth stays on but no cool air
You replaced the ac compressor, and the clutch stays on, but the compressor does not run ???
Not sure I am following your info here.
If the ac clutch stays engaged the compressor should be running. You should have one hot and one cold ac line and the radiator fan should be running.
Aug 04, 2012 | 1999 Cadillac Seville
Compressor and fans do not turn on until rev engine
I passed this question the first time I read it, so I will take a stab at it now.
The fans don't come on until the compressor has pumped the freon pressure up to say 150 or 200 psi. And the compressor clutch has to have voltage to engage the clutch.
I wonder if the clutch is going and needs 14 volts instead of 12 to engage ? Or the relay that powers the clutch ?
Speeding up the engine would increase voltage from the alternator.
This is assuming the serpentine belt is tight and everything else is working correctly.
I think I would swap the relay with another and put a meter on that circuit to the ac clutch to see what it takes to engage it.
Jul 24, 2012 | 1992 Buick Regal
Radiator fan not turning on as usual
Turn ACC on at low temperature. Open the hood to see if the AC compressor clutch either is engaged or cycles on and off. And also see if the radiator fan is on. The ACC and ACC radiator fan relay should pull them both on.
Jun 03, 2010 | 1989 Buick Century
After i put the ac on my bmw x5 2003 get over heat and smell burn
pls. check your ac compressor magnetic clutch attached in front of ur compressor if its working/ ac clutch engage when u turn the ac switch on and disengage when u turn the ac switch off/ it normally makes a clacking sound when it engage with the rotation of ur compressor/ if its not engaging it means ur magnetic clutch is stuck up giving excessive load to ur engine thats why it overheats/ it smell burnt because its magnetic coil is fried/ or check cooling system of ur car might be that coolant is empty/ fan is not working/ radiator is clogged or thermostatic valve is stuck blocking coolant flow....
Apr 09, 2010 | 2003 BMW 5 Series
2005 stratus w/burning smell, ac cycling fast and blowing hot air
Sounds like your ac system in low. To get the compressor to engage you must find ac resistor (usually under hood with fuses) and cross connect circuits. Most time right to left corners, you can hear and see compressor clutch engage. Now, fill system with proper refrigerant.
Once charged, compressor will=should cut on and off properly.
Jun 25, 2009 | 1999 Dodge Stratus
There seems to be no leaks but ac is blowing hot at the freon is full
Verify a/c compressor is engaged when commanded. Put a/c settings to max and fans on high. Look at end of compressor and verify clutch (outside disc portion is rotating). Also verify radiator cooling fans are operating simultaneously with a/c on.
Mar 29, 2009 | 1999 Ford Taurus
Heating & Cooling Logo
120 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
